[GRASS-user] Convert 32bit geotiff to a 16bit tiff file
hello grass members,
i am no specialist in gis-software-usage and file fomrat coneversion. but
for a project in 3d i have the files from this website
(http://deepreef.org/bathymetry/65-3dgbr-bathy.html)
you find the GMT/netCDF bathymetry grid [zip] 1.1 GBytes which is a 32bit
geotiff with the necessary bathymetry hights. i need thise file to be
concerted to a 16 bit file for the usage in e.g. cinema4d which can only
read 16nit files. but the problem is, that i do not no how to convert it
with the right grass export adjustments so the tiff file keeps it's constant
black to white gradient.
i always end up with a 16 bit file which is shaded from the origin of 0
meters hight. that meens thet for every value above 0 the shadiong is from
black to grey for higher values but for every hight below 0 the gradient
range will start from white to gray so ther is a sharp cut at 0 meters and
not like the greyscale you see on the webpage. does anybody know how this
tiff could be converted to a regual grayscale starting from black (minimal
hight) to white (maximal height?)
thank you, ixtract
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Convert-32bit-geotiff-to-a-16bit-tiff-file-tp5791303p5791303.html
