[GRASS-user] convert from NetCDF to ESRI Shapefile + scripting + install FC5.
I am new to Grass and I am wondering if it has capabilities to convert NetCDF
files to vector shapefiles? Any other format for which there exist a program
that converts it to shapefiles would also do.
Is it possible to use Grass in automated scripts? (bash/ksh/perl)
I also need some hints on installing it on Fedora Core 5 (EM64T CPU). It seems
to be missing some files (I'm guessing this is bcs it looking the wrong
places):
Error: Missing Dependency: libsqlite3.so.0 is needed by package gdal
Error: Missing Dependency: libhdf5.so.0 is needed by package gdal
Error: Missing Dependency: libgeos.so.2 is needed by package gdal-bin
Error: Missing Dependency: libsqlite3.so.0 is needed by package gdal-bin
Error: Missing Dependency: libhdf5.so.0 is needed by package gdal-bin
Error: Missing Dependency: libproj.so.0 is needed by package grass
Error: Missing Dependency: libgeos.so.2 is needed by package qgis
Error: Missing Dependency: libfftw.so.2 is needed by package grass
Error: Missing Dependency: libsqlite3.so.0 is needed by package qgis
Error: Missing Dependency: libgeos_c.so.1 is needed by package postgis
Error: Missing Dependency: libproj.so.0 is needed by package postgis
Error: Missing Dependency: libproj.so.0 is needed by package grass-bin
Error: Missing Dependency: libfftw.so.2 is needed by package grass-bin
Error: Missing Dependency: libproj.so.0 is needed by package qgis
hdf5, geos, proj, fftw and sqlite are all installed.
Is there any x86_64 packages available somewhere, the ones I tried are i386
ones?
Bjørge Solli - Office:+47 55205847
Mohn-Sverdrupsenteret, Nansensenteret, Høyteknologisenteret T47
Thormöhlensgate 47, 5006 Bergen, Norway - www.nersc.no
Google Earth: www.nersc.no/GE - TOPAZ: topaz.nersc.no
Bjørge Solli napisa?(a):
If your GDAL/OGR is built with NetCDF then v.in.ogr should handle this
format.
ogr2ogr (if GDAL built with NetCDF)
Sure. See /where/your/grass/lives/scripts and Grass WIKI AddOns page for
examples.
places):
How are you installing Grass and it's dependencies (source/rpm/else)?
ones?
http://grass.itc.it/grass61/binary/linux/snapshot
You haven't looked too much, have you ;)?
Maciek
> seems to be missing some files (I'm guessing this is bcs it looking the
> wrong places):
dl: http://ftp.gwdg.de/pub/misc/freegis/intevation/freegis/fedora/5/RPMS/*
yum install *.rpm
This did not find its deps as it should, but I managed to find out which
packages that should be installed by googling.
> i386 ones?
But no /stable/ ones? And no rpm? I prefer rpm if I can.
> > i386 ones?
The GRASS 6.1.0 version will be published in the next days.
We try to make RPMs available as well.
