[GRASS-user] Converting from xy location to latlong projection
I imported the Global Land Cover Characteristics database v2.0, but cannot get it to have a latlon projection. By using the Force Lat/Lon maps to fit into geographic coordinates option, I keep getting the error: The '-l' flag only works in Lat/Lon locations.
I tried it without this option and I imported the dataset but with the XY location (unprojected) map projection. I would like to convert the xy location projection to latlon. Ive tried using the r.proj command, but it assumes that I already have a raster map with the latlon projection available. I also tried to do it through the Settings tab of the GUI, but wasnt successful. Any help would be appreciated. Thanks.
regards,
Darren
Darren Slevin
Postgraduate Research Student
The University of Edinburgh
Grant Institute
The King's Buildings
West Mains Road
Edinburgh
EH9 3JW
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
it is better to create a new lat/lon Location than to try and
convert a simple xy Location into a lat/lon one by hand. all
maps within a single Location will share the same map projection.
You can't mix and match (lat/lon uses a radial coordinate system;
simple xy uses a Cartesian one). after importing into a lat/lon
Location (with '-l') be sure to double check map bounds with
r.info, and fix with r.region if needed.
Hamish
