[GRASS-user] Converting polygons to lines
I need to convert a road network in polygons to lines to do a network analysis.
I converted polygons to line by using v.type.bl- converting boundaries to lines. Then instead of getting single lines, i'm getting border lines over the polygon that was there earlier (No polygon its now line data). I tried cleaning options in GRASS but it didnt work.
Please provide me with guidelines on how to convert it to line data enabling to do network analysis.
Thanks
View this message in context: http://n2.nabble.com/Converting-polygons-to-lines-tp2589231p2589231.html
Well, if roads are polygons it colud be a problem.
if you don't need atributes of roads I sugest to convert polygons to raster, run r.thin, and convert raster to lines. But in that way you will lost road attributes.
supunmali pisze:
Thanks
Is that mean it is not possible?? I need the attribute data to do network analysis (e.g. optimal path). Pls suggest a method.
supunmali pisze:
Thanks
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/Converting-polygons-to-lines-tp2589231p2589760.html
