I have a huge raster, representing the slopes of a huge DEM (Rows: 25960, Columns: 23211, Total Cells: 602557560, Type CELL).
I would like to use R.to.vect to convert it to a vector layer of type area. Due to memory requirements, it does not work in one step.
I thought of splitting the raster into several smaller rasters (let's say into 100 smaller rasters of the same resolution) for which I could use r.to.vect to create the vector layers and in a final step patch the vector layers together again.
Before going into the details: is this a feasible approach (I can't reduce the resolution as the resolution is needed) or is there another solution?
But I am stuck in the first step:
how can I split one large raster layer into several smaller?
and:
What is the easiest way to write the script to do the calculations for all 100 raster layers? (I haven't used the scripting in GRASS 6.2.1 yet, but I have done a bit scripting under the bash shell)
Any help is welcome,
Rainer
NEW EMAIL ADDRESS AND ADDRESS:
Rainer.Krug@uct.ac.za
RKrug@sun.ac.za WILL BE DISCONTINUED END OF MARCH
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
Biology (UCT)
Leslie Hill Institute for Plant Conservation
University of Cape Town
Rondebosch 7701
South Africa
you probably only need to split it into 4 parts, not 100.
sure. use v.patch to recombine the parts, but mind the attributes carry
through.
probably several
actually you don't need to, just change the region with g.region.
Raster ops only happen in the current region. set the north/south
bounds to a quarter of the map's height and then r.to.vect will
only work on that part of it. Vector ops (for the most part) ignore
the current region settings.
and:
for MAP in `g.mlist type=rast pattern=*` ; do
echo "[$MAP]"
g.region rast=$MAP
r.to.vect $MAP ....
done
thanks a lot for your information - I'll try it out and come back if I have further problems
Rainer
through.
probably several
and:
echo "[$MAP]"
g.region rast=$MAP
r.to.vect $MAP ....
done
Hamish
Biology (UCT)
Rondebosch 7701
South Africa
