Each state has its own CRS. When I create a new location for a project in
that state I'd like to copy PROJ_INFO and PROJ_UNITS from that state's
location to the new project location.
Looking at the g.* commands I am not seeing how to do this with g.region,
g.proj, or other module.
Also, can I change the CRS for an existing location or only when it's being
created?
TIA,
Rich
On 2019-08-26 at 22:38 +02, Rich Shepard <rshepard@appl-ecosys.com> wrote...
created?
You can, but it is rare that you should do it, and a fairly low-level operation. It is required in some edge cases, like when setting up a rotated pole coordinate system.
What is your use-case or intended goal/behavior/setup? Perhaps there are easier and more appropriate methods.
-k.
Ken,
That's what I thought
When I start spatial analyses on a new project I want to set the location
using that state's 'official' CRS. While I thought I had done this when I
created the project location the PROJ_INFO file did not reflect this.
Rich
