[GRASS-user] copying mouse location to clipboard in gis.m
Hi all
In gis.m, as you mouse over a map, the current easting and northing is displayed in the lower right hand corner of the map window. This makes it easy to, for example, find the coordinates of an intersection on a street map by simply moving the cursor over the intersection and writing down the coordinates.
My problem is, is there any way to copy those coordinates to the clipboard with a keystroke command so they can be pasted somewhere else, rather than having to write them down by hand? I’ve tried the usual ctrl-c / ctrl-x kind of things with the Pointer, Query, and Measure tools selected, but nothing I try seems to put anything on the clipboard.
Does anyone know the answer to this one (or is there another way to do this using v.digit or something similar?)
Here’s a link to a screenshot with the coordinate box highlighted in case I haven’t been clear:
https://php10.ucsf.edu/ufostudy/transfer/screenshot.html
Many thanks in advance
Peter Davidson
Social & Behavioral Sciences
University of California, San Francisco
pete davidson pisze:
Hi all
else, rather than having to write them down by hand? I've tried the
the clipboard.
Here's a link to a screenshot with the coordinate box highlighted in
case I haven't been clear:
Query the map - the coordinates of where you clicked are in the gis.m
output window then, even if no object was found. Copy & paste from there.
Maciek
Maciej Sieczka
www.sieczka.org
Ahh! That worked! Thanks so much. I’d looked in the output window before, but had missed the coordinates because I have so much attribute data tied to the map.
Thanks again
Peter
On Sun, Dec 28, 2008 at 2:42 PM, Maciej Sieczka <msieczka@sieczka.org> wrote:
Hi all
the clipboard.
Maciek
Maciej Sieczka
www.sieczka.org
On Tue, December 30, 2008 19:07, pete davidson wrote:
Ahh! That worked! Thanks so much. I'd looked in the output window
before,
to
the map.
It would be nice to have the option to only query coordinates, not
attributes. Maybe you could add a wish to the tracker ?
Moritz
Thanks again
Peter
Hi all
the clipboard.
there.
Maciek
Maciej Sieczka
www.sieczka.org
grass-user mailing list
grass-user@lists.osgeo.org
