I apologize in advance for cross-posting this message, but I need to
quickly resolve this issue so I can proceed with the project. I posted this
to the proj4j mail list Friday (yes, I know it was a holiday), but have seen
no traffic on that list at all, and no responses to this request. Perhaps
someone here can help me.
There are three points whose geographic coordinates I have in long/lat. I
need to convert these to the Oregon Lambert Conformal Conic projection with
the Washington-Oregon adjustment. When I try doing this with the cs2cs tool I
get incorrect values as a result.
This is the input file:
#longitude|latitude
122:30:32.43W|45:19:19.49N
122:30:17.92W|45:18:52.45N
122:29:34.08W|45:18:47.16N
This is the command line I used:
cs2cs +proj=latlong +datum=NAD83 +to +proj=lcc +datum=NAD83 +ellps=GRS80 \
+lat_1=43.0 +lat_2=45.5 +lat_0=41.75 +lon_0=-120.5 +x_0=1312336 +y_0=0 +nadgrids=WO
The above values are taken from the metadata for the Oregon LCC:
stdparll 43.000000
stdparll 45.500000
long center -120.500000
latprj origin 41.750000
false east 1312335.958000 (International feet)
false north 0.000000
North American Datum of 1983
Geodetic Reference System 80
semiaxis 6378137.000000
denflat 298.257222
And these are the results:
#Easting|Northing
1154847.51|398797.24
1155143.02|397955.05
1156093.62|397768.55
Not only do these seem reversed, they are not at all within the bounds of
the other project maps.
I have the middle location on a separate map that was imported to GRASS
from an ESRI file, and its coordinates are approximately 796758.58,
1305792.74. Those values are in easting, northing order (at least, that's
the way I presume the GRASS-6.4 wxPython display presents them), and differ
in magnitude from what cs2cs produced.
What have I done incorrectly? How should I properly translate the long/lat
values to lcc for my project?
Rich
Proj4j mailing list
Proj4j@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/proj4j
