[GRASS-user] Cost Path
Hello list,
I have a raster obtained through r.mapcalc whose cells values represent friction or cost.
To finish my study I’m lacking one final step - calculate the least cost path!
How do I do it? I’ve tried r.cost but the result is not wat I expected - My desired output is just a line from A to B, crossing the least valued cells.
Thanks in advance,
André Mano
Associação Leonel Trindade
SOCIEDADE DE HISTÓRIA NATURAL
Apartado 25 2564-909 Torres Vedras Portugal
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto do Ameal 2565-641 Ramalhal
http://alt-shn.blogspot.com
www.alt-shn.org
On 07/02/12 14:39, ALT SHN wrote:
Hello list,
friction or cost.
I suppose that is friction per cell.
To finish my study I'm lacking one final step - calculate the least cost
path!
How do I do it? I've tried r.cost but the result is not wat I expected -
cells.
Use r.cost with the coordinate of (or the vector or raster file containing) A as start point. Then r.drain with B as starting point.
Moritz
I have resolved with:
r.walk -k elevation=your_dtm friction=your_friction output=walkout start_points=A stop_points=B
afterwards
r.drain -c input=walkout output=drainout vector_points=B
perhaps it is need a filling of the dtm and also of walkout map in order to avoid aq loop effect
All the best,
Roberto
2012/2/7 Moritz Lennert <mlennert@club.worldonline.be>
Hello list,
friction or cost.
path!
cells.
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
@ Roberto
Thank you for the hint. It’s a nice way arround for a future purpose.
The friction map I am using was build from various inputs, one of them the DEM (slope). So, if I understood right, using r.walk would be redundant beacause slope and altitude are already considered in the friction map.
Best Regards,
André
2012/2/8 Roberto Marzocchi <roberto.marzocchi@gmail.com>
afterwards
All the best,
Roberto
Hello list,
friction or cost.
path!
cells.
Moritz
www.alt-shn.org
