[GRASS-user] could the region change between 2 commands in a single Bash script?
Hi!
I'm writing a Bash script that
1. outputs the region settings into a temp file, to create a Grass
   ASCII raster header (to be used in step 4)
2. outputs 2 rasters to xyz ascii files
   a. r.stats -1g raster1 > file1.xyz
   b. r.stats -1g raster2 > file2.xyz
3. processes them, converts the resust into a single Grass ASCII raster
4. imports it with r.in.ascii (header created based on region settings
   obtained in step 1)
2a and 2b might take some time.
The question: if I run my script in background, and then I change the
region before eg. step 2a completes, is there any danger that 2b will
be run in a different region?
I hope not, I need 2a and 2b product to be the same number of lines,
the same coordinates.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
   obtained in step 1)
Yes.
However, you can force the use of a different region by setting either
of the environment variables WIND_OVERRIDE or GRASS_REGION.
WIND_OVERRIDE should be the name of a saved region (created with e.g.
"g.region save=..."), while GRASS region should be a complete region
definition in the same format as a region file except that newlines
are replaced with semicolons.
E.g.
  region=myscript.$$
  g.region save=$region
  export WIND_OVERRIDE=$region
  g.remove region=$region
On Thu, 1 Jun 2006 17:31:07 +0100
E.g.
  region=myscript.$$
Thank you Glynn! This will help.
Maciek
