[GRASS-user] count vector points (quadrat count)
Dear,
How can I count vector points by region resolution (quadrat count) and write the results in a raster map (in order to perform r.mapcalc on these observed frequencies).
Is v.to.rast the command I should use (v.to.rast input=myvec output=myras use=??? value=???)
Robbie
You could try r.in.xyz using 'method=n' which will count points per cell
(resolution chosen in g.region) and write a raster map allocating the number
count to the cell.
John
On Thursday 08 April 2010 07:39:12 Robbie Heremans wrote:
Dear,
use=??? value=???)
Robbie
Thanks John.
v.out.ascii input=myvec format=point | r.in.xyz input=- output=myras method=n type=FCELL x=1 y=2 z=3
does the job.
Robbie
2010/4/8 John Tate <john.tate@ntlworld.com>
You could try r.in.xyz using ‘method=n’ which will count points per cell
count to the cell.
John
Dear,
use=??? value=???)
Robbie
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, Apr 8, 2010 at 10:55 AM, Robbie Heremans
<robbie.heremans@gmail.com> wrote:
Thanks John.
does the job.
Excellent.
Now a FAQ:
http://grass.osgeo.org/wiki/Count_points_in_raster_cells
