I have a raster map with categorical values.
I have many occurrence of alone-pixels, where all neighbours
are different from a central pixels. So I need to change all pixels
that differ from alll its neighbours for the “mode” value.
I know that “r.neighbours …method=mode” return the mode value.
Now I need to identify only those pixels that differ from neighbours.
I think one way is count all occurrence the value of central pixel
on a windows (like 3x3, 5x5), and attrib it on a bynary map, where
“ones” is for those positons where central pixels have frequency 1,
and “zeros” for those potisions where central pixels have frequency >1.
that differ from alll its neighbours for the "mode" value.
I know that "r.neighbours ..method=mode" return the mode value.
you might check out the r.game_of_life module in wiki addons for inspiration.
"ones" is for those positons where central pixels have frequency 1,
and "zeros" for those potisions where central pixels have frequency >1.
Maybe you want method=interspersion:
interspersion
The percentage of cells containing values which differ from the
values assigned to the center cell in the neighborhood, plus 1. In
the above example, the interspersion is:
5/8 * 100 + 1 = 63.5
The result is rounded to the nearest integer (in this case 64).
