[GRASS-user] create 3d plane from vector lines
I'm stuck here, trying to create 3d vertical surfaces from 2d vector
lines (to represent faults in nviz). hints?
TIA
Carlos
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
Hi Carlos. You can use v.surf.rst. Description (from command help):
“Spatial approximation and topographic analysis from given … isoline data in vector format to floating point raster format using regularized spline with tension.”
Basic usage (remember to adjust region settings):
v.surf.rst input=contour layer=0 elev=surface
Where:
contour : name of the map containing your vector lines (iso lines or level contours).
surface : name of the raster map, obtained from interpolation of the vector lines.
More info here: http://grass.itc.it/grass62/manuals/html62_user/v.surf.rst.html
I hope that this help you.
José
Saludos (sorry for my bad english)
2008/9/9 Carlos Guâno Grohmann <carlos.grohmann@gmail.com>
I’m stuck here, trying to create 3d vertical surfaces from 2d vector
TIA
Carlos
“Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive.”
–The winning entry in a “What were HAL’s first words” contest judged
Can’t stop the signal.
grass-user mailing list
grass-user@lists.osgeo.org
Hello José.
v.surf.rst is not exactly what I want here, although I could duplicate
my vector lines with different elevations and then interpolate the
values to get _raster_ surfaces. I was thinking more in a v.extrude
way, just that it currently extrude areas to form facets or shifts
lines, but it doesn't create planes from line (AFAICT).
cheers
Carlos
On Tue, Sep 9, 2008 at 22:59, José María Michia
"Spatial approximation and topographic analysis from given ... isoline data
with tension."
Where:
contours).
lines.
More info here:
José
TIA
Carlos
_________________
_________________
Hi Carlos,
how about using v.delaunay?
If you have two lines for each fault, you can triangulate the space in between.
But im not sure if this works with vertical lines.
If you export those lines to VTK, you can triangulate vertical planes
with the VTK delaunay triangulator in ParaView.
Soeren
-------- Original-Nachricht --------
Datum: Tue, 9 Sep 2008 23:32:37 -0300
Von: "Carlos \\"Guâno\\" Grohmann" <carlos.grohmann@gmail.com>
An:
CC: grass-user <grass-user@lists.osgeo.org>
Betreff: Re: [GRASS-user] create 3d plane from vector lines
Hello José.
cheers
Carlos
data
spline
> with tension."
> Where:
level
> contours).
vector
> lines.
> More info here:
> José
>> Hi all,
>> TIA
>> Carlos
>> _________________
>> _______________________________________________
_________________
GMX Kostenlose Spiele: Einfach online spielen und Spaß haben mit Pastry Passion!
http://games.entertainment.gmx.net/de/entertainment/games/free/puzzle/6169196
Thanks Soren, I got the effect I wanted in Paraview, using the "linear
extrusion" filter.
cheers
Carlos
On Wed, Sep 10, 2008 at 04:54, "Sören Gebbert" <soerengebbert@gmx.de> wrote:
Hi Carlos,
Soeren
An:
Hello José.
cheers
Carlos
data
spline
> with tension."
> Where:
level
> contours).
vector
> lines.
> More info here:
> José
>> Hi all,
>> TIA
>> Carlos
>> _________________
_________________
_________________
2008/9/10 Carlos Guâno Grohmann <carlos.grohmann@gmail.com>:
extrusion" filter.
Hey pal,
does that method allows for representation of dipping surfaces?
You know you should think about that too =]
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.224 = GG86jc
Hey Mate,
you know, simple dipping surfaces are easy, r.plane will do the job,
but _complex_ dipping surfaces (like real faults) are still a work in
progress..
cheers
G
On Wed, Sep 10, 2008 at 21:00, Paulo Marcondes <paulomarcondes@gmail.com> wrote:
extrusion" filter.
Hey pal,
_________________
