[GRASS-user] create a point map
Hello,
I’d appreciate any help with this. I have a list of Easting and Northing coords, along with a value for each point. I’d like to turn this into a map that I can then display and use for analysis. Or at the very least, is there a command that will allow me to identify where a given easting/northing is located in the display?
Thank You
Janet
Janet,
Have a look at r.in.xyz:
http://grass.itc.it/grass63/manuals/html63_user/r.in.xyz.html
Eric Patton
email: epatton@nrcan.gc.ca
From: grassuser-bounces@grass.itc.it [mailto:grassuser-bounces@grass.itc.it] On Behalf Of Janet Choate
Sent: Thursday, December 21, 2006 12:18 PM
To: grassuser@grass.itc.it
Subject: [GRASS-user] create a point map
Hello,
Thank You
Janet
You may also want to try r.in.ascii. I found that in GRASS 6.1 r.in.xyz does not exist.
-----Original Message-----
From: grassuser-bounces@grass.itc.it on behalf of Patton, Eric
Sent: Thu 12/21/2006 10:00 AM
To: Janet Choate
Cc: grassuser@grass.itc.it
Subject: RE: [GRASS-user] create a point map
Janet,
Eric Patton
Hello,
Thank You
Janet
does not exist.
Unless you are sure you want a raster map, I would actually recommend
v.in.ascii.
Moritz
To: Janet Choate
Janet,
Eric Patton
  Hello,
  I'd appreciate any help with this. I have a list of Easting and
Northing coords, along with a value for each point. I'd like to turn
  Thank You
  Janet
grassuser mailing list
