[GRASS-user] Create a raster starting from a coordinate pair
is there some grass raster command to create a raster starting from a
coordinate pair?
Something like r.createraster input=x,y output=myraster
Thank you,
View this message in context: http://osgeo-org.1560.x6.nabble.com/Create-a-raster-starting-from-a-coordinate-pair-tp5093513.html
What do you mean exactly with creating a raster from a coordinate pair?
If you want to align a raster to your coordinates you might have a look into g.region
and set appropriate resolution and extend coordinates.
To create a raster based on coordinates, eg. set a raster value at a specific coordinate
pair to a specific value you could use r.mapcalc:
E.g. Set the value 1 at the cell x=52, y=10
r.mapcalc “newmap = if(abs(x()-52.0)<0.001 && abs(y()-10.00)<0.001, 1)”
If you know the specific row and column and resolution you could also use:
r.mapcalc “newmap = if(row()-1 == int(($n-10.0)/$nsres) && col()-1 == int((52.0-$w)/$ewres), 1)”
Thanks to Glynn who taught me these things some time ago on the mailing list :slight_smile:
/Johannes
On Tue, Dec 10, 2013 at 1:02 PM, aborruso <aborruso@gmail.com> wrote:
coordinate pair?
Thank you,
grass-user mailing list
grass-user@lists.osgeo.org
Hi Johannes,
thank you.
You are rigth, I have to be more understandable.
I have defined region, with a defined extent and a defined resolution.
Starting from a coordinate pair I would like to create a boolean raster
(with the same extent and resolution of my region) that "register" my pair
(in example 1 for my pixel and 0 for all the rest).
Best regards,
View this message in context: http://osgeo-org.1560.x6.nabble.com/Create-a-raster-starting-from-a-coordinate-pair-tp5093513p5093523.html
Hi Andrea,
may be you need something like that:
http://grass.osgeo.org/grass65/manuals/r.in.xyz.html
I'm not sure if that was the problem.
all the best
Ivan
On Tue, 2013-12-10 at 05:01 -0800, aborruso wrote:
Hi Johannes,
thank you.
Best regards,
Ciao Ivan,
thank you.
Not exactly. I would like to use as inpunt only a coordinate pair and not
another file.
Best regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Create-a-raster-starting-from-a-coordinate-pair-tp5093513p5093527.html
Here a short example for a subregion of the North Carolina Sample Dataset with resolution 10x10 m
g.region -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 224820
south: 224450
west: 641120
east: 641660
nsres: 10
ewres: 10
rows: 37
cols: 54
cells: 1998
When I run following command I get a raster map with the value 1 for the coordinate pair 641335.0/224515.00 (cell center). All other cell have the value 0.
r.mapcalc “newmap = if(abs(x()-641335.0)<0.001 && abs(y()-224515.00)<0.001, 1, 0)”
/Johannes
On Tue, Dec 10, 2013 at 2:21 PM, Ivan Marchesini <ivan.marchesini@gmail.com> wrote:
Hi Andrea,
I’m not sure if that was the problem.
all the best
Ivan
Hi Johannes,
thank you.
(with the same extent and resolution of my region) that “register” my pair
Best regards,
Hi Johannes,
thank you, thank you, thank you.
I'll try
View this message in context: http://osgeo-org.1560.x6.nabble.com/Create-a-raster-starting-from-a-coordinate-pair-tp5093513p5093530.html
On 10/12/13 14:44, aborruso wrote:
Hi Johannes,
Another solution:
- create a vector point with v.in.ascii or v.edit
- transform that into a raster with v.to.rast
Moritz
coordinate pair?
Hi Andrea,
maybe this comes pretty close:
http://grass.osgeo.org/grass64/manuals/r.in.poly.html
