[GRASS-user] Create location fails in docker
I need to run GRASS in a docker image but I have issues apparently about permissions.
My docker image is built on a dockerfile:
Margherita Di Leo
Hi again,
I try to reformulate my question:
Margherita Di Leo
Hi Madi,
Am 30.09.2021 09:46 schrieb Margherita Di Leo:
Hi again,
On Wed, Sep 29, 2021 at 9:32 PM Margherita Di Leo <diregola@gmail.com>
wrote:
grass --text -c EPSG:4326 $GRASSDATA/france -e
The error message:
File "/usr/bin/grass", line 390, in get_grass_config_dir
os.mkdir(directory)
PermissionError: [Errno 13] Permission denied: '/.grass7'
During handling of the above exception, another exception occurred:
File "/usr/bin/grass", line 2218, in <module>
main()
File "/usr/bin/grass", line 2001, in main
grass_config_dir = get_grass_config_dir()
File "/usr/bin/grass", line 395, in get_grass_config_dir
_("Failed to create configuration directory '%s' with error:
%s")
NameError: name '_' is not defined
os.mkdir(directory)
What does this error message mean? Why is it trying to write in the
/.grass7 folder ?
Whenever you launch GRASS GIS with the grass startup script, it writes the chosen Gisdbase/Location/Mapset info into .grass7/rc. If you launch GRASS GIS for the first time, it first creates the directory .grass7 which is the part that fails with a permission error.
I'm no Docker expert at all, but I think you have to explicitly run the container with parameters indicating the devices one can access from within.
And what does the name '_' refer to?
This seems to be linked to the translation handling:
%s")
Note the '_' in front of the string which marks it as a translatable string.
There was a bug related to this a while ago, but it was fixed (https://trac.osgeo.org/grass/ticket/3875). Maybe a locale issue ?
Moritz
2021-09-30 10:46 GMT+03:00, Margherita Di Leo <diregola@gmail.com>:
/.grass7 folder ? And what does the name '_' refer to?
It means that you need to fix your environment before starting GRASS.
Check your $HOME setting.
Māris.
Hi Moritz,
Hi Madi,
PermissionError: [Errno 13] Permission denied: ‘/.grass7’
/.grass7 folder ?
But isn’t .grass7/rc folder supposed to be written in the home directory? In my docker image I set the user and a home directory is created for it…
I’m no Docker expert at all, but I think you have to explicitly run the
within.
I’m trying to figure… I set a workdir and give full permissions to the user to it, but still the .grass7 folder is not written there nor in the home. Is there a way to “force” the grass configuration files to be written somewhere else?
Margherita Di Leo
[RESOLVED]
Simply the docker machine was deployed with changes I was unaware of. Sorry for the noise and thank you so much for the brainstorming.
Margherita Di Leo
