For the defined region I want to create a map of the Manning's n friction
value (0.030) in each cell. v.in.ascii tells me it cannot find the input
text file:
v.in.ascii -n -b input=manning.txt output=manning format=point
ERROR: Unable to open input file <manning.txt>
The file has no coordinates, only the single value 0.030. I am not finding
what is missing here. A pointer is needed.
Rich
Rich,
If you want to create a raster map with an uniform value, just use mapcalc:
r.mapcalc exp='manning=0.03'
And that's it.
Laurent
2017-02-22 16:40 GMT-06:00 Rich Shepard <rshepard@appl-ecosys.com>:
text file:
Rich
grass-user mailing list
grass-user@lists.osgeo.org
mapcalc: r.mapcalc exp='manning=0.03'
Laurent,
That is much simpler than what I tried to do.
Rich
