[GRASS-user] Creating a png file with multiple vector maps
Good morning :slight_smile:
I’m using GRASS 7.4.1 on a Linux cluster so I only have command-line capability. I have two vector layers (a country boundary polygon and part of an administrative area map - also polygons). I am trying to automate creating a PNG file of the admin areas overlaying the country boundary therefore all work has to be command-line (in a bash script). I’ve tried this two ways - using the d.mon start=png method and also the ps.map method as described below. The d.mon method appears to generate the image with only one vector map (not both) and only colors the borders - it won’t use the fill_color setting. The ps.map method seems to work but assumes the image is on a sheet of paper so there’s a ton of extra white-space. I’d like to use d.mon but I can use ps.map if someone could please let me know how to export only the computational region without all the extra ‘paper’ in the image. Here’s my code:
g.region vector=‘Country’
export GRASS_RENDER_IMMEDIATE=png
export GRASS_RENDER_WIDTH=640
export GRASS_RENDER_HEIGHT=480
export GRASS_RENDER_TRANSPARENT=true
export GRASS_RENDER_TRUECOLOR=true
export GRASS_RENDER_FILE=$HOME/country_admin.png
export GRASS_RENDER_FILE_COMPRESSION=0
export GRASS_MESSAGE_FORMAT=plain
d.mon start=png
d.vect map=Country color=210:210:210 fill_color=153:153:153 display=shape type=area
d.vect map=admin_area color=153:153:153 rgb_column=area_color display=shape type=area
d.mon stop=png
This only produces a png with the last vector listed and only the borders are colored with the rgb_column values.
If I do this without the d.mon start/stop lines … i.e. relying on the GRASS_RENDER_IMMEDIATE=png only, then only one vector map is converted to png however it DOES do the color fill properly. With either above method the png is the correct size.
Now using ps.map (same env variable set as above):
ps.map input=$HOME/ps_rules.txt out=$HOME/country_admin.ps --overwrite
where ps_rules.txt is:
border y
color 81:81:81
end
vareas admin_area
layer 1
rgbcolumn area_color
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
We don’t have pstopng but we do have ghostscript:
gs-dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -dTextAlphaBits=4 -dGraphicsAlphaBits=4 -r300 -sOutputFile=$HOME/country_admin.png $HOME/country_admin.ps
This creates the correct image (color fills, etc) but has white margins and a lot of white space below the image like it is printed at the top of a piece of paper.
does anyone have any idea how to create a png with multiple vector maps overlaying each other (and not have the extra whitespace too)?
v/r
Chris
On Tue, Feb 9, 2021 at 10:25 AM Chris Bartolomei via grass-user <grass-user@lists.osgeo.org> wrote:
d.mon start=png
d.mon stop=png
I think you are missing GRASS_RENDER_FILE_READ=TRUE:
https://grass.osgeo.org/grass78/manuals/pngdriver.html
Regarding rgb_column, I am not sure, didn’t have time to test.
Anna
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
v/r
Chris
grass-user mailing list
Hi Anna - thank you for the suggestion - I tried it but alas, still it only outputs a single vector map (layer). I can get either the Country vector or the admin_areas vector, but not both overlaid.
:frowning:
Chris
On Tuesday, February 9, 2021, 1:20:52 PM EST, Anna Petrášová kratochanna@gmail.com wrote:
d.mon start=png
d.mon stop=png
Anna
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
v/r
Chris
:frowning:
Chris
I realized you are using both environmental variables and d.mon, that might cause some issues, you use one or the other. So try to remove the lines starting with d.mon.
Hope that helps,
Anna
On Tuesday, February 9, 2021, 1:20:52 PM EST, Anna Petrášová <kratochanna@gmail.com> wrote:
d.mon start=png
d.mon stop=png
Anna
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
v/r
Chris
Good morning Anna,
It took quite a while of trial and error but I worked out a method that kindof works:
First off - unless someone says otherwise, you can’t use the PNG driver (d.mon) method to overlay more than one polygon vector. Sorry - it just doesn’t work. You CAN use the ps.map method - that works really well generating the image however it by default assumes you are printing on an A4 piece of paper so there’s all sorts of white space. The image is centered at the top of this fictional piece of paper. In your postscript rules file you can use the “maploc” command to position the image elsewhere on the page. This is necessary because the next trick changes the paper dimensions but it assumes the origin is the lower left corner and therefore clips anything that is above the new dimensions. Back to postscript commands in the rules file first though … the ps.map maploc command uses inches (why?? it should be points) so an A4 page is 8.27" x 11.69" points are 1/72 of an inch thus 595p x 842p - it also has a default 36p margin (0.5 inch). You’ll need those numbers later. maploc also lets you set the size of your image box: maploc {x offset from left edge} {y offset from top} {width of box} {height of box} Note: this is all done via a BASH script with GRASS 7.4 on Linux (RHEL 7), not python. This is my postscript rules file:
maploc 0.1 6.815 6.5 4.875 #468p x 351p map box moved down towards the bottom of the page
note that if you push it too far down to where the box would run off the bottom, the image is
resized to fit on the page so do some testing to come up with the correct values
also I found the computational region controls the aspect ratio so although I say
6.5 x 4.875 with the above maploc command, I got a 6.5 x 3.8 inch box.
border y # add a border to the map frame (box)
color 81:81:81 # shade of gray
end # end the border controls
vareas admin_area # top vector layer to display
layer 1 # attribute table to use
rgbcolumn area_color # name of column holding R:G:B values to fill the polygons
color 153:153:153 #boundary color
end # end the admin_area controls
vareas Country # this is the bottom vectors to display
color 210:210:210 #boundary color
fcolor 153:153:153 #fill color for all polygons
end # end the Country controls
Here’s the command to run to generate the postscript file:
ps.map input=$HOME/ps_rules.txt out=$HOME/color_admin.ps --overwrite
To convert the postscript to PNG I had to use ghostscript - there are other tools you can use though.
gs -dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -r300 -dTextAlphaBits=4 -dGraphicsAlphaBits=4 -dDEVICEWIDTHPOINTS=473 -dDEVICEHEIGHTPOINTS=276 -dFIXEDMEDIA -dPSFitPage -sOutputFile=$HOME/color_admin.png -c “<</PageOffset [-34 78]>> setpagedevice” -f $HOME/color_admin.ps
So the above line needs some explaining (http://www.ghostscript.com/doc/9.27/Use.htm) but in a nutshell, the parameters to play with are first the Pageoffset [x y] values. They are in points not inches … 1/72 inch = 1 point … remember the 1/2" margins? the -34 gives me 2 points of white space to the left edge of the map frame, the 78 I had to play with to push the map frame down to the right spot.
Next is the DEVICEWIDTHPOINTS and DEVICEHEIGHTPOINTS … again in points … this “trims” the paper to height and width … set something then run it and view the results. Adjust and run again until you get it correct.
It’s a royal pain but it seems to work this way. It would sure be nice to create a GRASS workspace file and just say “convert this workspace to an image” with everything all laid out nicely - like Arc does exporting their mxd map files…
I hope this helps someone !
:slight_smile:
Chris
On Wednesday, February 10, 2021, 11:08:00 PM EST, Anna Petrášová kratochanna@gmail.com wrote:
:frowning:
Chris
Hope that helps,
Anna
d.mon start=png
d.mon stop=png
Anna
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
v/r
Chris
Would this addon be useful? https://grass.osgeo.org/grass78/manuals/addons/m.printws.html
On February 11, 2021 6:55:24 PM Chris Bartolomei via grass-user grass-user@lists.osgeo.org wrote:
Good morning Anna,
:slight_smile:
Chris
:frowning:
Chris
Hope that helps,
Anna
d.mon start=png
d.mon stop=png
Anna
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
v/r
Chris
Hi Chris,
For me, the following works with the current stable GRASS GIS (7.8.5) and using maps from the NC demo data set:
export GRASS_RENDER_FILE_READ=TRUE
g.region vect=census_wake2000
d.vect map=census_wake2000@PERMANENT fill_color=none
d.vect map=roadsmajor@PERMANENT color=255:0:0:255
d.vect map=schools_wake@PERMANENT fill_color=0:128:0:255 icon=basic/circle size=10
I attach a small thumbnail of the resulting PNG file.
Moritz
On 11/02/21 18:54, Chris Bartolomei via grass-user wrote:
Good morning Anna,
First off - unless someone says otherwise, you can't use the PNG driver (d.mon) method to overlay more than one polygon vector. Sorry - it just doesn't work. You CAN use the ps.map method - that works really well generating the image however it by default assumes you are printing on an A4 piece of paper so there's all sorts of white space. The image is centered at the top of this fictional piece of paper. In your postscript rules file you can use the "maploc" command to position the image elsewhere on the page. This is necessary because the next trick changes the paper dimensions but it assumes the origin is the lower left corner and therefore clips anything that is above the new dimensions. Back to postscript commands in the rules file first though ... the ps.map maploc command uses inches (why?? it should be points) so an A4 page is 8.27" x 11.69" points are 1/72 of an inch thus 595p x 842p - it also has a default 36p margin (0.5 inch). You'll need those numbers later. maploc also lets you set the size of your image box: maploc {x offset from left edge} {y offset from top} {width of box} {height of box} Note: this is all done via a BASH script with GRASS 7.4 on Linux (RHEL 7), not python. This is my postscript rules file:
# note that if you push it too far down to where the box would run off the bottom, the image is
# resized to fit on the page so do some testing to come up with the correct values
# also I found the computational region controls the aspect ratio so although I say
# 6.5 x 4.875 with the above maploc command, I got a 6.5 x 3.8 inch box.
Here's the command to run to generate the postscript file:
gs -dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -r300 -dTextAlphaBits=4 -dGraphicsAlphaBits=4 -dDEVICEWIDTHPOINTS=473 -dDEVICEHEIGHTPOINTS=276 -dFIXEDMEDIA -dPSFitPage -sOutputFile=$HOME/color_admin.png -c "<</PageOffset [-34 78]>> setpagedevice" -f $HOME/color_admin.ps
So the above line needs some explaining (http://www.ghostscript.com/doc/9.27/Use.htm) but in a nutshell, the parameters to play with are first the Pageoffset [x y] values. They are in points not inches ... 1/72 inch = 1 point ... remember the 1/2" margins? the -34 gives me 2 points of white space to the left edge of the map frame, the 78 I had to play with to push the map frame down to the right spot.
Next is the DEVICEWIDTHPOINTS and DEVICEHEIGHTPOINTS ... again in points ... this "trims" the paper to height and width ... set something then run it and view the results. Adjust and run again until you get it correct.
It's a royal pain but it seems to work this way. It would sure be nice to create a GRASS workspace file and just say "convert this workspace to an image" with everything all laid out nicely - like Arc does exporting their mxd map files...
:slight_smile:
Chris
On Wednesday, February 10, 2021, 11:08:00 PM EST, Anna Petrášová <kratochanna@gmail.com> wrote:
On Tue, Feb 9, 2021 at 4:41 PM Chris Bartolomei <surfcjb@yahoo.com <mailto:surfcjb@yahoo.com>> wrote:
    Chris
Hope that helps,
Anna
    <kratochanna@gmail.com <mailto:kratochanna@gmail.com>> wrote:
        I'm using GRASS 7.4.1 on a Linux cluster so I only have
        has to be command-line (in a bash script). I've tried this two
        the borders - it won't use the fill_color setting. The ps.map
        paper so there's a ton of extra white-space. I'd like to use
        extra 'paper' in the image. Here's my code:
        g.region vector='Country'
        d.mon start=png
        d.mon stop=png
    <https://grass.osgeo.org/grass78/manuals/pngdriver.html&gt;
    Regarding rgb_column, I am not sure, didn't have time to test.
    Anna
        If I do this without the d.mon start/stop lines ... i.e. relying
        --overwrite
        border y
          color 81:81:81
          end
        vareas admin_area
          layer 1
          color 153:153:153
          end
        vareas Country
          color 210:210:210
          fcolor 153:153:153
          end
        We don't have pstopng but we do have ghostscript:
        margins and a lot of white space below the image likeit is
        whitespace too)?
        v/r
        Chris
        <https://lists.osgeo.org/mailman/listinfo/grass-user&gt;
(attachments)
Mortiz - are those vector layers areas ? I’m guessing the census is an area, the roads are lines and the schools are points, yes? I’m having an issue overlaying two area maps (polygons). i can only get one to show … I have tried your method with all the export GRASS_RENDER* variables but I have a country polygon map as the bottom later and a selection of a few administrative areas (provinces/states) as the top map and I can only get one or the other to show up. It almost seems as if the transparency doesn’t work and what should be transparent in the admin map is actually the background color and blocks the country from being seen.
Could you please try your method with a couple area (polygon) vector maps overlaying each other?
Thanks!
:slight_smile:
Chris
On Tuesday, February 16, 2021, 4:19:16 AM EST, Moritz Lennert mlennert@club.worldonline.be wrote:
Hi Chris,
Moritz
Good morning Anna,
kindof works:
bottom of the page
correct values
although I say
the polygons
the right spot.
:slight_smile:
Chris
:frowning:
Chris
Hope that helps,
Anna
<kratochanna@gmail.com mailto:[kratochanna@gmail.com](mailto:kratochanna@gmail.com)> wrote:
<grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)> wrote:
d.mon start=png
d.mon stop=png
<https://grass.osgeo.org/grass78/manuals/pngdriver.html>
Anna
–overwrite
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
whitespace too)?
v/r
Chris
<https://lists.osgeo.org/mailman/listinfo/grass-user>
On 16/02/21 15:54, Chris Bartolomei wrote:
Mortiz - are those vector layers areas ? I'm guessing the census is an area, the roads are lines and the schools are points, yes? I'm having an issue overlaying two area maps (polygons). i can only get one to show ... I have tried your method with all the export GRASS_RENDER* variables but I have a country polygon map as the bottom later and a selection of a few administrative areas (provinces/states) as the top map and I can only get one or the other to show up. It almost seems as if the transparency doesn't work and what should be transparent in the admin map is actually the background color and blocks the country from being seen.
export GRASS_RENDER_FILE=$HOME/test.png
d.vect map=census_wake2000@PERMANENT fill_color=grey
d.vect map=censusblk_swwake@PERMANENT fill_color=red
I've tried with
export GRASS_RENDER_TRANSPARENT=TRUE
and
export GRASS_RENDER_TRANSPARENT=FALSE
As you can see in the attached images, the overlay seems to work without any issues (or I don't understand what you are looking for exactly) and setting GRASS_RENDER_TRANSPARENT decides on whether the background should be transparent or not.
A second test in the same data set, but with different layers:
export GRASS_RENDER_FILE=$HOME/test_NC_TRUE.png
g.region vect=boundary_county
d.vect map=boundary_county@PERMANENT
d.vect map=boundary_municp@PERMANENT fill_color=255:255:0:255
export GRASS_RENDER_FILE=$HOME/test_NC_FALSE.png
Again, the overlay works, at least as I would have expected.
Moritz
On Tuesday, February 16, 2021, 4:19:16 AM EST, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Chris,
d.vect map=census_wake2000@PERMANENT <mailto:census_wake2000@PERMANENT> fill_color=none
d.vect map=roadsmajor@PERMANENT <mailto:roadsmajor@PERMANENT> color=255:0:0:255
d.vect map=schools_wake@PERMANENT <mailto:schools_wake@PERMANENT> fill_color=0:128:0:255
Moritz
> Good morning Anna,
> kindof works:
> bottom of the page
> correct values
> although I say
> the polygons
> the right spot.
> :slight_smile:
> Chris
> :frowning:
> Chris
> Hope that helps,
> Anna
> <kratochanna@gmail.com <mailto:kratochanna@gmail.com> <mailto:kratochanna@gmail.com>> wrote:
> Hi,
> <grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org> <mailto:grass-user@lists.osgeo.org>> wrote:
> d.mon start=png
> d.mon stop=png
> Anna
> --overwrite
> border y
> color 81:81:81
> end
> vareas admin_area
> layer 1
> color 153:153:153
> end
> vareas Country
> color 210:210:210
> fcolor 153:153:153
> end
> whitespace too)?
> v/r
> Chris
(attachments)
Well - that does indeed work for you. I’ll try your settings when I get into the office - we’re running GRASS on a RHEL 7 cluster - and see what I can come up with.
It would be sooo much better if it worked like yours did!
Thank you so much for taking the time and testing this out
:slight_smile:
v/r
Chris
On Tuesday, February 16, 2021, 11:07:10 AM EST, Moritz Lennert mlennert@club.worldonline.be wrote:
I’ve tried with
and
any issues (or I don’t understand what you are looking for exactly) and
Moritz
Hi Chris,
d.vect map=census_wake2000@PERMANENT mailto:[census_wake2000@PERMANENT](mailto:census_wake2000@PERMANENT)
fill_color=none
d.vect map=roadsmajor@PERMANENT mailto:[roadsmajor@PERMANENT](mailto:roadsmajor@PERMANENT)
color=255:0:0:255
d.vect map=schools_wake@PERMANENT mailto:[schools_wake@PERMANENT](mailto:schools_wake@PERMANENT)
Moritz
Good morning Anna,
kindof works:
bottom of the page
correct values
although I say
the polygons
<http://www.ghostscript.com/doc/9.27/Use.htm>) but in a nutshell, the
the right spot.
correct.
:slight_smile:
Chris
<mailto:surfcjb@yahoo.com mailto:[surfcjb@yahoo.com](mailto:surfcjb@yahoo.com)>> wrote:
:frowning:
Chris
Hope that helps,
Anna
<mailto:kratochanna@gmail.com mailto:[kratochanna@gmail.com](mailto:kratochanna@gmail.com)>> wrote:
<mailto:grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)>>
d.mon start=png
d.mon stop=png
<https://grass.osgeo.org/grass78/manuals/pngdriver.html>>
Anna
–overwrite
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
whitespace too)?
v/r
Chris
<https://lists.osgeo.org/mailman/listinfo/grass-user>>
Ohhhhh !! Sooooooo close ! I can get the two vector maps to overlay and display but no matter what I do I cannot get them to do a color fill … ugh … fill_color does nothing. I can use “d.vect map=admin_area color=red” and the boundaries change to red, but “d.vect map=admin_area color=black fill_color=red” and i do not get any filled color. So frustrating. I thought maybe my shapefile imported as just a boundary but when I do a “v.category input=admin_area option=report” I get:
Layer/table 1/admin_area
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 59 1 25
area 0 0 0
face 0 0 0
kernel 0 0 0
all 59 1 25
Should I have areas in there too ??
I wonder if the import went wonky… what is strange is that the ps.map tool fills the polygons just fine.
Moritz - could please I ask you to do a v.category on one of your vector maps (v.category input=censuslbk_wwake@PERMANENT option=report) and see if it has areas in it or just centroids like I have?
Thanks again for the help!
:slight_smile:
Chris
On Tuesday, February 16, 2021, 11:20:31 AM EST, Chris Bartolomei surfcjb@yahoo.com wrote:
:slight_smile:
v/r
Chris
I’ve tried with
and
Moritz
Hi Chris,
fill_color=none
color=255:0:0:255
Moritz
Good morning Anna,
kindof works:
bottom of the page
correct values
although I say
the polygons
the right spot.
correct.
:slight_smile:
Chris
:frowning:
Chris
Hope that helps,
Anna
d.mon start=png
d.mon stop=png
Anna
–overwrite
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
whitespace too)?
v/r
Chris
Hi Chris,
On 17/02/21 02:30, Chris Bartolomei wrote:
Ohhhhh !! Sooooooo close ! I can get the two vector maps to overlay and display but no matter what I do I cannot get them to do a color fill ... ugh ... fill_color does nothing. I can use "d.vect map=admin_area color=red" and the boundaries change to red, but "d.vect map=admin_area color=black fill_color=red" and i do not get any filled color. So frustrating. I thought maybe my shapefile imported as just a boundary but when I do a "v.category input=admin_area option=report" I get:
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 59 1 25
area 0 0 0
face 0 0 0
kernel 0 0 0
all 59 1 25
I'm not really sure what 'area' in the output of v.category actually refers to, as areas cannot have categories in GRASS GIS.
In order to see if you have areas in your file, check with v.info:
I wonder if the import went wonky.... what is strange is that the ps.map tool fills the polygons just fine.
GRASS 7.8.5 (nc_spm_08_grass7):~ > v.info -t boundary_county
nodes=1114
points=0
lines=0
boundaries=1910
centroids=926
areas=926
islands=130
primitives=2836
map3d=0
but
>v.category boundary_county op=report
Layer/table: 1/boundary_county
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 926 1 926
area 0 0 0
face 0 0 0
kernel 0 0 0
all 926 1 926
In order to find out if the issue comes from your data or from your installation of GRASS GIS, you can also download the NC demo data set from https://grass.osgeo.org/download/data/#NorthCarolinaDataset and try to reproduce what I did in order to see if it works.
Moritz
On Tuesday, February 16, 2021, 11:20:31 AM EST, Chris Bartolomei <surfcjb@yahoo.com> wrote:
Well - that does indeed work for you. I'll try your settings when I get into the office - we're running GRASS on a RHEL 7 cluster - and see what I can come up with.
:slight_smile:
v/r
Chris
On Tuesday, February 16, 2021, 11:07:10 AM EST, Moritz Lennert <mlennert@club.worldonline.be> wrote:
d.vect map=census_wake2000@PERMANENT <mailto:census_wake2000@PERMANENT> fill_color=grey
d.vect map=censusblk_swwake@PERMANENT <mailto:censusblk_swwake@PERMANENT> fill_color=red
I've tried with
and
d.vect map=boundary_county@PERMANENT <mailto:boundary_county@PERMANENT>
d.vect map=boundary_municp@PERMANENT <mailto:boundary_municp@PERMANENT> fill_color=255:255:0:255
Moritz
> <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
> Hi Chris,
> d.vect map=census_wake2000@PERMANENT <mailto:census_wake2000@PERMANENT> <mailto:census_wake2000@PERMANENT>
> fill_color=none
> d.vect map=roadsmajor@PERMANENT <mailto:roadsmajor@PERMANENT> <mailto:roadsmajor@PERMANENT>
> color=255:0:0:255
> d.vect map=schools_wake@PERMANENT <mailto:schools_wake@PERMANENT> <mailto:schools_wake@PERMANENT>
> Moritz
> > Good morning Anna,
> > kindof works:
> > bottom of the page
> > correct values
> > although I say
> > the polygons
> > (http://www.ghostscript.com/doc/9.27/Use.htm >
> <http://www.ghostscript.com/doc/9.27/Use.htm&gt;\) but in a nutshell, the
> > the right spot.
> correct.
> > :slight_smile:
> > Chris
> > :frowning:
> > Chris
> > Hope that helps,
> > Anna
> <mailto:kratochanna@gmail.com <mailto:kratochanna@gmail.com>>> wrote:
> > Hi,
> <mailto:grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>>>
> > d.mon start=png
> > d.mon stop=png
> > https://grass.osgeo.org/grass78/manuals/pngdriver.html >
> > <https://grass.osgeo.org/grass78/manuals/pngdriver.html >
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html&gt;&gt;
> > Anna
> > --overwrite
> > border y
> > color 81:81:81
> > end
> > vareas admin_area
> > layer 1
> > color 153:153:153
> > end
> > vareas Country
> > color 210:210:210
> > fcolor 153:153:153
> > end
> > whitespace too)?
> > v/r
> > Chris
> > _______________________________________________
> > https://lists.osgeo.org/mailman/listinfo/grass-user >
> > <https://lists.osgeo.org/mailman/listinfo/grass-user >
> <https://lists.osgeo.org/mailman/listinfo/grass-user&gt;&gt;
Good afternoon Moritz - thank you for the feedback :slight_smile:
I’ve been able to get GRASS 7.8 running with msys on my pc so I can send images etc. now… I tried repeating what I had done at work and I have the same results … I also downloaded the Spearfish dataset as you suggested and brought in the boundary_county vector. I can go into Properties and fill color orange and outline gray, but I go to the console and do the d.vect map=boundary_county color=red fill_color=orange and all I get is the red boundaries.I attached an image of everything … the Layer Manager, the Display window, the msys console window with my commands run and all my exported GRASS variables, and the resultant png image.
I’ve tried this with several other polygon vector files and I get the same darn thing. Can you see anything wrong with my variable settings ?
GRASS 7.8.4> v.info -t boundary_county@WarningPoints #from the Spearfish dataset
nodes=1114
points=0
lines=0
boundaries=1910
centroids=926
areas=926
islands=130
primitives=2836
map3d=0
GRASS 7.8.4> env | grep GRASS
MANPATH=C:\OSGEO4~1\apps\grass\grass78\docs\man;C:\Users\Chris\AppData\Roaming\GRASS7\addons\docs\man
GRASS_PYTHON=C:\OSGEO4~1\bin\python3.exe
GRASS_RENDER_TRANSPARENCY=true
GRASS_PAGER=more
GRASS_GNUPLOT=gnuplot -persist
GRASS_RENDER_PNG_COMPRESSION=0
GRASSBIN=C:\OSGEO4~1\apps\grass\grass78\bin
GRASS_SH=C:\OSGEO4~1\apps\msys\bin\sh.exe
PATH=/c/OSGEO4~1/apps/grass/grass78/lib:/c/OSGEO4~1/apps/grass/grass78/bin:/c/Users/Chris/AppData/Roaming/GRASS7/addons/bin:/c/OSGEO4~1/apps/Python37:/c/OSGEO4~1/apps/Python37/Scripts:/c/OSGEO4~1/apps/Python27/Scripts:/c/OSGEO4~1/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/system32/WBem:/usr/bin:/c/Program Files/RStudio/bin:/c/OSGEO4~1/apps/grass/grass78/bin:/c/OSGEO4~1/apps/grass/grass78/scripts:/c/OSGEO4~1/apps/grass/grass78/lib:.:/c/OSGEO4~1/apps/Python37/lib/site-packages/pywin32_system32
GRASS_PROJSHARE=C:\OSGEO4~1\share\proj
PS1=GRASS 7.8.4>
GRASS_VERSION=7.8.4
GRASS_HTML_BROWSER=start
GRASS_ADDON_BASE=C:\Users\Chris\AppData\Roaming\GRASS7\addons
GRASS_RENDER_FILE_READ=true
GRASS 7.8.4> d.vect map=boundary_county@WarningPoints color=red fill_color=orange
d.vect complete.
GRASS 7.8.4>
Thanks again … and sorry to bother you so much!
:slight_smile:
Chris
On Wednesday, February 17, 2021, 7:57:08 AM EST, Moritz Lennert mlennert@club.worldonline.be wrote:
Hi Chris,
ugh … fill_color does nothing. I can use "d.vect map=admin_area
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 59 1 25
area 0 0 0
face 0 0 0
kernel 0 0 0
all 59 1 25
I’m not really sure what ‘area’ in the output of v.category actually
nodes=1114
points=0
lines=0
boundaries=1910
centroids=926
areas=926
islands=130
primitives=2836
map3d=0
but
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 926 1 926
area 0 0 0
face 0 0 0
kernel 0 0 0
all 926 1 926
Moritz
I can come up with.
:slight_smile:
v/r
Chris
being seen.
fill_color=grey
mailto:[censusblk_swwake@PERMANENT](mailto:censusblk_swwake@PERMANENT) fill_color=red
I’ve tried with
and
d.vect map=boundary_county@PERMANENT mailto:[boundary_county@PERMANENT](mailto:boundary_county@PERMANENT)
d.vect map=boundary_municp@PERMANENT mailto:[boundary_municp@PERMANENT](mailto:boundary_municp@PERMANENT)
Moritz
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)>
wrote:
Hi Chris,
mailto:[census_wake2000@PERMANENT](mailto:census_wake2000@PERMANENT) <mailto:census_wake2000@PERMANENT
mailto:[census_wake2000@PERMANENT](mailto:census_wake2000@PERMANENT)>
fill_color=none
<mailto:roadsmajor@PERMANENT mailto:[roadsmajor@PERMANENT](mailto:roadsmajor@PERMANENT)>
color=255:0:0:255
<mailto:schools_wake@PERMANENT mailto:[schools_wake@PERMANENT](mailto:schools_wake@PERMANENT)>
Moritz
Good morning Anna,
that
kindof works:
driver
just
image is
postscript
changes
corner
maploc
8.27" x
Note: this
bottom of the page
correct values
although I say
inch box.
the polygons
<http://www.ghostscript.com/doc/9.27/Use.htm >
<http://www.ghostscript.com/doc/9.27/Use.htm>>) but in a nutshell, the
They are
the right spot.
points
correct.
workspace to
exporting
:slight_smile:
Chris
<mailto:surfcjb@yahoo.com mailto:[surfcjb@yahoo.com](mailto:surfcjb@yahoo.com)>>> wrote:
:frowning:
Chris
remove the
Hope that helps,
Anna
<mailto:kratochanna@gmail.com mailto:[kratochanna@gmail.com](mailto:kratochanna@gmail.com)>>> wrote:
mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org) <mailto:grass-user@lists.osgeo.org
mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)>>>
d.mon start=png
d.mon stop=png
<https://grass.osgeo.org/grass78/manuals/pngdriver.html>>>
Anna
relying
vector map
–overwrite
border y
color 81:81:81
end
vareas admin_area
layer 1
color 153:153:153
end
vareas Country
color 210:210:210
fcolor 153:153:153
end
whitespace too)?
v/r
Chris
<https://lists.osgeo.org/mailman/listinfo/grass-user>>>
(attachments)
Sorry, Chris, I lost this out of my sight.
I don't see anything immediately wrong. Maybe it is a specific MS Windows issue I cannot reproduce here in GNU/Linux.
@Helmut any ideas ?
Moritz
I've been able to get GRASS 7.8 running with msys on my pc so I can send images etc. now... I tried repeating what I had done at work and I have the same results ... I also downloaded the Spearfish dataset as you suggested and brought in the boundary_county vector. I can go into Properties and fill color orange and outline gray, but I go to the console and do the d.vect map=boundary_county color=red fill_color=orange and all I get is the red boundaries.I attached an image of everything ... the Layer Manager, the Display window, the msys console window with my commands run and all my exported GRASS variables, and the resultant png image.
I've tried this with several other polygon vector files and I get the same darn thing. Can you see anything wrong with my variable settings ?
nodes=1114
points=0
lines=0
boundaries=1910
centroids=926
areas=926
islands=130
primitives=2836
map3d=0
GRASS_PAGER=more
PS1=GRASS 7.8.4>
GRASS_VERSION=7.8.4
d.vect complete.
GRASS 7.8.4>
Thanks again ... and sorry to bother you so much!
:slight_smile:
Chris
On Wednesday, February 17, 2021, 7:57:08 AM EST, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Chris,
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 59 1 25
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 59 1 25
> maps (v.category input=censuslbk_wwake@PERMANENT <mailto:censuslbk_wwake@PERMANENT> option=report) and see
nodes=1114
points=0
lines=0
boundaries=1910
centroids=926
areas=926
islands=130
primitives=2836
map3d=0
but
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 926 1 926
area 0 0 0
face 0 0 0
kernel 0 0 0
all 926 1 926
from https://grass.osgeo.org/download/data/#NorthCarolinaDataset >and try
Moritz
> I can come up with.
> :slight_smile:
> v/r
> Chris
> being seen.
> fill_color=grey
> I've tried with
> and
> d.vect map=boundary_county@PERMANENT <mailto:boundary_county@PERMANENT> <mailto:boundary_county@PERMANENT>
> d.vect map=boundary_municp@PERMANENT <mailto:boundary_municp@PERMANENT> <mailto:boundary_municp@PERMANENT>
> Moritz
> > <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be> <mailto:mlennert@club.worldonline.be>>
> wrote:
> > Hi Chris,
> <mailto:census_wake2000@PERMANENT>>
> > fill_color=none
> <mailto:roadsmajor@PERMANENT <mailto:roadsmajor@PERMANENT>>
> > color=255:0:0:255
> <mailto:schools_wake@PERMANENT <mailto:schools_wake@PERMANENT>>
> > Moritz
> > > Good morning Anna,
> that
> > > kindof works:
> driver
> just
> image is
> postscript
> changes
> corner
> maploc
> 8.27" x
> Note: this
> > > bottom of the page
> > > correct values
> > > although I say
> inch box.
> > > the polygons
> <http://www.ghostscript.com/doc/9.27/Use.htm >>
> <http://www.ghostscript.com/doc/9.27/Use.htm&gt;&gt;\) but in a nutshell, the
> They are
> > > the right spot.
> points
> > correct.
> workspace to
> exporting
> > > :slight_smile:
> > > Chris
> > > :frowning:
> > > Chris
> remove the
> > > Hope that helps,
> > > Anna
> <mailto:kratochanna@gmail.com <mailto:kratochanna@gmail.com>>>> wrote:
> > > Hi,
> <mailto:grass-user@lists.osgeo.org>>>>
> > > d.mon start=png
> > > d.mon stop=png
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html >>
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html&gt;&gt;&gt;
> > > Anna
> relying
> vector map
> > > --overwrite
> > > border y
> > > color 81:81:81
> > > end
> > > vareas admin_area
> > > layer 1
> > > color 153:153:153
> > > end
> > > vareas Country
> > > color 210:210:210
> > > fcolor 153:153:153
> > > end
> > > whitespace too)?
> > > v/r
> > > Chris
> <https://lists.osgeo.org/mailman/listinfo/grass-user >>
> <https://lists.osgeo.org/mailman/listinfo/grass-user&gt;&gt;&gt;
@Helmut any ideas ?
tested here in the following way in OSGeo4W-winGRASS 7.8.5
(1) changing the working directory via GUI > change working directory
cd "D:\temp\testgrassrender"
Working directory changed to:
(2) in OSgeo4W-winGRASS-windows console (no msys needed!), also change here to the new wd:
C:\>cd D:\temp\testgrassrender
C:\>d:
(3) put the variables and d.-commands into a bat-file into the working directory (D:\temp\testgrassrender\mytest.bat):
REM start of the batch file
set GRASS_RENDER_IMMEDIATE=png
set GRASS_RENDER_WIDTH=640
set GRASS_RENDER_HEIGHT=480
set GRASS_RENDER_TRANSPARENT=true
set GRASS_RENDER_TRUECOLOR=true
set GRASS_RENDER_FILE_COMPRESSION=0
set GRASS_MESSAGE_FORMAT=plain
set GRASS_RENDER_FILE_READ=TRUE
d.vect map=census_wake2000 fill_color=none
d.vect map=roadsmajor color=255:0:0:255
d.vect map=schools_wake fill_color=0:128:0:255 icon=basic/circle size=10
REM end of the batch file
=> see here: in order to set a variable in the windows world, use e.g. set GRASS_RENDER_IMMEDIATE=png instead if export GRASS_RENDER_IMMEDIATE=png in the *nix world
(4) start your batch file in the windows command line:
D:\temp\testgrassrender>mytest.bat
D:\temp\testgrassrender>set GRASS_RENDER_IMMEDIATE=png
D:\temp\testgrassrender>set GRASS_RENDER_WIDTH=640
D:\temp\testgrassrender>set GRASS_RENDER_HEIGHT=480
D:\temp\testgrassrender>set GRASS_RENDER_TRANSPARENT=true
D:\temp\testgrassrender>set GRASS_RENDER_TRUECOLOR=true
D:\temp\testgrassrender>set GRASS_RENDER_FILE_COMPRESSION=0
D:\temp\testgrassrender>set GRASS_MESSAGE_FORMAT=plain
D:\temp\testgrassrender>set GRASS_RENDER_FILE_READ=TRUE
D:\temp\testgrassrender>g.region vect=census_wake2000
D:\temp\testgrassrender>d.vect map=census_wake2000 fill_color=none
d.vect komplett.
D:\temp\testgrassrender>d.vect map=roadsmajor color=255:0:0:255
d.vect komplett.
D:\temp\testgrassrender>d.vect map=schools_wake fill_color=0:128:0:255 icon=basic/circle size=10
d.vect komplett.
(5) see attached the result png - it looks like the same as Moritz's example
kind regards
Helmut
(attachments)
Helmut … thank you for your example however I think there is a misunderstanding of what I am trying to do. I am using GRASS on Linux (on a cluster) and the issue I am experiencing is overlaying two polygon maps (layers in Arc-speak). Points and lines on top of ONE set of polygons works fine as you have shown, however using two or more polygon maps (layers) does not seem to work. I attached an example of what i am trying to achieve: Take for instance a polygon representing Italy and you wanted it colored dark gray, then you want to overlay on top of that an administrative map showing only the areas of Lazio and Liguria colored in blue but no other administrative areas. The result would look like the Italy_sample.png file i attached (I made is using ArcPro as i am not in the office with access to our cluster). This is what is not working using the d.mon=png, d.vect tools. Could you please try something similar and see if it works for you (on linux)?
v/r
Chris
On Tuesday, March 2, 2021, 2:38:45 PM EST, Helmut Kudrnovsky hellik@web.de wrote:
I don’t see anything immediately wrong. Maybe it is a specific MS
@Helmut any ideas ?
cd “D:\temp\testgrassrender”
C:>cd D:\temp\testgrassrender
C:>d:
d.vect komplett.
d.vect komplett.
d.vect komplett.
(5) see attached the result png - it looks like the same as Moritz’s example
kind regards
Helmut
(attachments)
Hi Chris,
In your previous message the settings you used had a lot of MS Windows paths in them, that’s why I thought you used that. If you’re not on Windows then these settings are wrong and this might explain your problem. Here’s what you sent:
GRASS_PAGER=more
PS1=GRASS 7.8.4>
GRASS_VERSION=7.8.4
All the C:\ paths indicate Windows.
Moritz
Am 11. März 2021 21:37:01 MEZ schrieb Chris Bartolomei surfcjb@yahoo.com:
v/r
Chris
@Helmut any ideas ?
C:>d:
d.vect komplett.
d.vect komplett.
d.vect komplett.
kind regards
Helmut
