Hello
I have created a classification map and I would like to convert it to a vectorial file. But instead of just converting I would really like to define scale (1:XXXX) of the output map and Minimum mapping area for each polygon. Is it possible?
Thanks
Usually before I post a message a try to find a similar question but I didn’t find anything.
Bye
Nikos
Hello
I have created a classification map (in raster) and I would like to convert it to a vectorial file. But instead of just converting I would really like to define scale (1:XXXX) of the output map and Minimum mapping area for each polygon. Is it possible?
Thanks
Bye
Nikos
On Monday 07 December 2009, Nikos Dumakis wrote:
Hello
Thanks
didn't find anything.
Bye
Nikos
Would r.reclass.area help?
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
Hello Dylan
Sorry for my delay on replying to your message.
Ok I reading r.reclass.area manual and I’m not sure what is it doing.
Because If I define a limit to "lesser value option that sets the <= area size limit " all the small blocks are not eliminated. Each block now has a specific color but and it’s related with its size but when I use “Query raster” the value is the original classification value.
And by the way it creates a clump. What is a clump?
Thank you all
Best regards
Niko
On Mon, Dec 7, 2009 at 5:30 PM, Dylan Beaudette <debeaudette@ucdavis.edu> wrote:
Hello
Thanks
Bye
Nikos
Dylan
Dylan Beaudette
530.754.7341
