The region in the project location is incorrect. With only one small data
set imported I decided to start over by deleting that location in
/data/grassdata/.
I created a subdirectory for the project /data/grassdata/mohler/ then
started grass within that directory: grass79 -c epsg:2838 --gui PERMANENT
The EPSG code is defined as:
EPSG 2838 NAD83(HARN) <http://www.spatialreference.org/ref/epsg/2838/>
proj4: +proj=lcc +lat_1=46 +lat_2=44.33333333333334 +lat_0=43.66666666666666 +lon_0=-120.5 +x_0=2500000 +y_0=0 +ellps=GRS80 +units=m +no_defs
but those are not the values seen by g.region:
GRASS 7.9.dev (mohler):/data/grassdata > g.region -p
projection: 99 (NAD83(HARN) / Oregon North)
zone: 0
datum: nad83harn
ellipsoid: grs80
north: 1
south: 0
west: 0
east: 1
nsres: 1
ewres: 1
rows: 1
cols: 1
cells: 1
What have I done incorrectly?
TIA,
Rich
Hi Rich,
On 2019-08-26 at 23:10 +02, Rich Shepard <rshepard@appl-ecosys.com> wrote...
No. Setting the region and location are different things. You set the location with your "-c EPSG:2838".
With only one small data set imported I decided to start over by
deleting that location in /data/grassdata/.
You haven't shown the import command, but you can set the region from imported data with:
g.region (raster=... | vector=....)
Or explicitly:
g.region e=... w=... n=... s=... res=...
If setting with vector=... you'll need to set the "res" explicitly.
Not set your region, just your location.
-k.
Ken,
While I know that regions are subsets within the bounds of the CRS defined
for a location I don't recall importing a vector or raster map and not being
able to zoom to its extents before explicitly setting a region.
Rich
On Mon, Aug 26, 2019 at 11:10 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
/data/grassdata/.
zone: 0
datum: nad83harn
ellipsoid: grs80
north: 1
south: 0
west: 0
east: 1
nsres: 1
ewres: 1
rows: 1
cols: 1
cells: 1
The purpose of g.region is to show/change the current computational region.
If you want to verify the CRS of the current location, use g.proj.
Markus M
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Markus M,
Ah, I totally forgot that.
Many thanks!
Rich
On 2019-08-27 at 16:42 +02, Rich Shepard <rshepard@appl-ecosys.com> wrote...
defined for a location I don't recall importing a vector or raster map
and not being able to zoom to its extents before explicitly setting a
region.
Perhaps in the earlier work the region was set w/o import based on how you created the location? If you created the location using "-c SomeGeoTiff.tif", then the region is set to that file. If you create it with "-c EPSG:nnnn", it doesn't know extent, resolution, etc. and the defaults, as you saw, are all 0 or 1.
-k.
Ken,
Yes, this explains the difference. Almost always prior project locations
were created using a .adf or .prj file with the CRS and the balance of the
files with the data.
Thanks for the insight.
Best regards,
Rich
