[GRASS-user] creating network only input points
hello.
how to create a network so that nodes are only the input points , as this grass gis adding nodes that make noise in my calculations, as are the beginning and end of each line and points outside the same network, this to be, and how I can make a network with my real points only.
I am using grass gis 65 svn in ubuntu linux of 64 bit
Thanks for your answers
Ricardo Rodríguez
Univalle
Hello,
can You, please, clarify Your idea and problem?
By definition - every line has two nodes and may have extra vertices.
Point is line with only one node. If You need just own nodes, put them
in different layer.
Maris.
2010/11/6, Ricardo Rodríguez <ricardorodot02@gmail.com>:
hello.
Ricardo Rodríguez
Univalle
hi, thanks for answering
to create the network I have a layer of segments and other points, I say put the points in a different and so is entering, so I worry that the network is not exclusively think my point  :S , you suggest.
I use this instruction that in grass gis 65 svn
**[v.net](http://v.net) in=lines points=nodes  alayer=lines  nlayer=points out=network**
thanks for your help
Ricardo Rodríguez
Univalle
