[GRASS-user] Creating new mapsets in current location
   The g.mapset man page confirms the way I've been using it: change to
another mapset in the current location. However, I need to re-project maps
existing in a different location.
   I've tried using it to create a new mapset in the current location (by
checking the box 'create mapset if it doesn't exist') but the name of a
mapset in the current location is required. The mapset does not yet exist
and I'm confused why there is an option to create it if it must already
exist.
   After re-projecting each mapset from the -feet to the -meters locations I
exit grass, then reload it after defining a new mapset name.
   Is there a better way to do this?
Rich
exist.
I
just tried here with
g.mapset -p
data
g.mapset -c mapset=t
g.mapset -p
t
g.mapset - Changes/reports current mapset.
Optionally create new mapset or list available mapsets in given location.
here it works: change to mapset t which should be created.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
g.mapset -p
t
Helmut,
   Ah, yes. I tried using the GUI and missed seeing the -c option. Normally I
use the command line, but I used the GUI earlier today.
Thanks very much,
Rich
g.mapset -p
t
Helmut,
Normally I
I've done it in the GUI.
best regards
Helmut
exist.
It doesn't have to exist, but you have to give it a name.
Moritz
