Hi again,
I am trying to create a sqlite database for my project and need some guidance.
1. Do particular field names have to appear in the database for GRASS to recognize them? Exampl STR_1?
2. How do I use the various field types (eg. TEXT, NUMERIC, BLOB, and INTEGER PRIMARY KEY)?
3. Do I need an entry number, or is the first number sufficient?
What I am doing currently is entering tombs. I currently need easing and northing data for UTM coordinates and catalog numbers (which enters as CAT. 1, CAT. 2, upto CAT. 75). Later, I may want to add fields like Townland name, finds, astronomical orientation, etc.
Thanks for any guidance you can offer.
Kurt
[please don't post to grassuser@grass.itc.it but to
<grass-user@lists.osgeo.org>]
On Fri, Jun 12, 2009 at 4:24 PM, Kurt Springs<ferret_bard@mac.com> wrote:
Hi again,
guidance.
No. Just avoid SQL reserved names.
db.execute should do everything which is supported by the DB backend.
What does that mean?
Should be possible.
Note that the new wxPython graphical user interface has a graphical attribute
manager.
