[GRASS-user] Creation of GISDBASE in a script
Hi list,
I'm trying to use GRASS 6.4.2 rc1 on a cluster, where each session is
launched on a TMP space. As a consequence, I cannot setup a GRASSDATA
db once for all - I need to upload the spatial data I want to work
with, create a tmp grassdata/location/mapset in a script, then launch
my GIS with another script. Unfortunately, I can't figure out how to
create the grassdata from scratch (not only the location, the whole
thing!), using a script (ie without any GUI).
I had this problem once with the dev version (grass70-svn), and the -c
flag resolved my problems [1]. But that solution does not seem to work
for this version.
Pierre
[1]: http://lists.osgeo.org/pipermail/grass-dev/2011-March/thread.html#53900
Scientist
Landcare Research, New Zealand
On Mon, Nov 7, 2011 at 4:11 AM, Pierre Roudier <pierre.roudier@gmail.com> wrote:
Hi list,
For GRASS 6, see in Addons "grass_create_location.sh":
http://trac.osgeo.org/grass/browser/grass-addons/general/grass_create_location
Hi list,
I’m trying to use GRASS 6.4.2 rc1 on a cluster, where each session is
my GIS with another script. Unfortunately, I can’t figure out how to
I am in a similar situation, where I am simulating on different cluster nodes and have spatial results in a GRASS database. I simply created a template grass database, and copied it to the nodes (I actually linked the PERMANENT mapset, as it containes several GB of data and is read only).
If you want to, you should be able to consolidate all mapsets in one final location, i.e. copying then under a unique name ito the location (I just leave them as separate gras databases).
Rainer
flag resolved my problems 1. But that solution does not seem to work
for this version.
Pierre
Scientist
grass-user mailing list
grass-user@lists.osgeo.org
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
Thanks for your answers,
I did saw this add-on, but isn't it generating a new location only (ie
not a new, entire GRASSDATA)?
Pierre
Scientist
On Mon, Nov 7, 2011 at 8:46 PM, Pierre Roudier <pierre.roudier@gmail.com> wrote:
You asked
"create a tmp grassdata/location/mapset in a script"
and creating the "grassdata/" is simply
mkdir grassdata
Then you can use the script indicating that directory or use Rainer's approach
to copy an existing empty location.
BTW: I only create temporary *mapsets* and work in the same location
on a cluster (in this case the location is valid for all jobs). Much easier...
Thanks for the clarification Markus et al., it works indeed,
Pierre
2011/11/8 Markus Neteler <neteler@osgeo.org>:
You asked
mkdir grassdata
Scientist
For GRASS 6, see in Addons “grass_create_location.sh”:
I did saw this add-on, but isn’t it generating a new location only (ie
You asked
“create a tmp grassdata/location/mapset in a script”
and creating the “grassdata/” is simply
mkdir grassdata
Then you can use the script indicating that directory or use Rainer’s approach
BTW: I only create temporary mapsets and work in the same location
on a cluster (in this case the location is valid for all jobs). Much easier…
One disadvantage though: as the location has to be on a shared volume, all data has to be transfered via the network backend of the cluster. If you need the data often, it might be considerably faster to copy the data to the local volume of the node, and work there and copy the results back.
Alternative approach: you can have linked the temporary mapset, which sits on the local volume of the node, into the location on the shared volume - best of both worlds?
Rainer
South Africa
Skype: RMkrug
Yes, see this script as an example:
http://grass.osgeo.org/wiki/Parallel_GRASS_jobs#The_Grid_Engine_script
# temporarily store *locally* the stuff to avoid NFS overflow/locking problem
## Remove XXX to enable
grep XXX/storage/local /etc/mtab >/dev/null && (
  if test "$MYMAPSET" = ""; then
temporarily store locally the stuff to avoid NFS overflow/locking problem
if test “$MYMAPSET” = “”; then
Very nice script - I might add some aspects to my script.
Rainer
South Africa
Skype: RMkrug
