Dear list,
I am trying to crop a raster map into a smaller area, but I am failing.
This wiki page link is quite clear:
“Make boundary into mask using r.mask then copy raster source to new map (g.copy). All cells outside of the mask will be omitted from the new copy.”
r.mask vector=myarea
g.copy --overwrite raster=OldRasterWithBigArea,NewRasterWithSmallArea
r.mask -r
I expected all cell outside were not going to be omitted, but replaced by NULL.
Regards
Marco
On 26/09/17 15:57, Marco Alicera wrote:
Dear list,
This wiki page link <https://grasswiki.osgeo.org/wiki/Cropping_maps> is quite clear:
"Make boundary into mask using r.mask <https://grass.osgeo.org/grass72/manuals/r.mask.html> then copy raster source to new map (g.copy <https://grass.osgeo.org/grass72/manuals/g.copy.html>\). All cells outside of the mask will be omitted from the new copy."
r.mask -r
I'm not sure I understand your last sentence, but AFAIK, the wiki info is wrong. g.copy works directly on the files and ignores mask and region settings. In your example, OldRasterWithBigArea and NewRasterWithSmallArea should be strictly identical.
You need to use r.mapcalc "new = old" while the mask is set to get a raster with everything outside the mask set to NULL.
Moritz
Dear list,
quite clear:
r.mask -r
by NULL.
I've rewritten the wiki page to try to make things clearer.
Moritz
For cropping, see also a new addon module called r.clip which clips according the computational region while respecting mask and the original raster resolution:
https://grass.osgeo.org/grass72/manuals/addons/r.clip.html
Testing and feedback welcome.
Vaclav
On Tue, Sep 26, 2017 at 10:35 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Dear list,
quite clear:
<https://grass.osgeo.org/grass72/manuals/g.copy.html>). All cells
r.mask -r
by NULL.
I’m not sure I understand your last sentence, but AFAIK, the wiki info
You need to use r.mapcalc “new = old” while the mask is set to get a
I’ve rewritten the wiki page to try to make things clearer.
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
About https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.clip/r.clip.py#L42
g.region align=original
is sufficient. You don’t need to specify nsres or ewres when aligning to a raster map because nsres and ewres of the raster map are used anyway for alignment.
Markus M
Vaclav
Dear list,
quite clear:
r.mask -r
by NULL.
Moritz
On Fri, Dec 1, 2017 at 10:39 AM, Markus Metz <markus.metz.giswork@gmail.com>
according the computational region while respecting mask and the *original*
raster resolution:
is sufficient. You don't need to specify nsres or ewres when aligning to a
alignment.
Fixed. Thanks MarkusM for the tip.
https://trac.osgeo.org/grass/changeset/71982
r.clip and v.clip are now missing in the Cropping maps wiki page if
somebody wants to contribute some text...
Vaclav
