[GRASS-user] Custom d.vect icons in WX-Python GUI
Hi GRASS-users,
I have a series of custom icons/symbols that I often use when I create maps or display layers inside of the wx-gui. Older versions of the d.vect UI would recognize my grass-6.4.x/etc/symbol/CustomDirName directory and the list of CustomIcons inside of it. With newer enhancements to the GUI which now displays the icon itself as opposed to directory/name only, I am no longer able to select any custom icons. Note: I can still use the command line to display vector layers using a custom icon (e.g. d.vect map=camp icon=custom/camp)
How can I build my version of GRASS to allow me to choose icons in a custom symbol directory using the d.vect UI.
I am convinced I have seen documentation on how to do that in the past, but a couple hours of searching around the wiki today has turned up empty.
Casey
p.s. Here is my Grass Builds System Info if relevant
GRASS version: 6.4.4svn
GRASS SVN Revision: 57320M
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.0
PROJ4: Rel. 4.9.0, 22 June 2013
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.2.0-51-generic-x86_64-with-Ubuntu-12.04-precise
Casey Vandenberg Geomatics Specialist
SJ Geophysics Ltd.
11966 95A Avenue Delta, BC, Canada, V4C 3W2
Office: 604.582.1100
Mobile: 778.928.1103
www.sjgeophysics.com
note you can also use "$MAPSET/symbol/group/name", but it has to be done
for each mapset. (perhaps we should also search ~/.grassX/symbols/ or
$GRASS_ADDON_PATH/symbols/ ? [tricky if multiple paths in ADDON_PATH])
the idea is to have custom addon items installed for you install-wide,
and survive a version upgrade or 'make distclean' without being deleted.
custom icons.
d.vect will get them if the module was built after they were installed.
d.graph might work directly with a newly installed symbol.
the d.mark addon script needs to be edited by hand, but just the (unique)
symbol name, not the group name.
to see them in the GUI you need to make a thumbnail image with ps.map andinkscape. See gui/images/symbols/README in the grass source code for a script to do that. Put the pngs in that same ./gui/images/symbols/ dir structure.
for sharing/backup/possibly get them installed by default consider to
contribute them to
http://grasswiki.osgeo.org/wiki/IconSymbols#Contributions
or somewhere in addons svn.
regards,
Hamish
