[GRASS-user] Cut DEM by SHP
Hi to all....
I wanted to ask a question...
Is it possible to cut a raster (dem) through a shape or a vector?
Thanks..
View this message in context: http://www.nabble.com/Cut-DEM-by-SHP-tf2708829.html#a7552313
If I understand correctly: (there are other 3D tools for planes)
g.region rast=MapName
v.to.rast
then either create a raster map named MASK (see r.mask) or
  r.mapcalc newmap='if(isnull(vect_mask), null(), MapName)'
                  # if( this , then do this, else do this )
Hamish
v.to.rast
Hamish
grassuser mailing list
grassuser@grass.itc.it
Thanks.
But with MASK is it not permanent?
while with r.mapcalc it's permanent map.
sorry my english!
View this message in context: http://www.nabble.com/Cut-DEM-by-SHP-tf2708829.html#a7569840
The mask will be in place as long as a raster map named "MASK" is there.
This affects maps that are read, not written.
for example: (spearfish dataset)
# will only save roads where the MASK is, as that is the only data read
r.mapcalc "MASK=if(isnull(fields))"
r.mapcalc test_rast=roads
g.remove MASK
d.rast test_rast
# will create map over entire region, regardless of MASK
r.mapcalc "test_num = x() * y()"
g.remove MASK
d.rast test_num
in that way, MASK can have a permanent effect to newly written maps.
Hamish
