I notice the that using Approach 2, the areas that was outside the set
region is white. The underlayung rasters are not visible (or only if I
set the opacity of "cut" to a low value).
If I use Approach 1 with r.mapcalc, the areas outside the region are
really NULL() (=transparent) and underlaying larger rasters are visible.
Only that the result "cut" from r.mapcalc has a new colortable.
Am I doing something wrong?
Why is the no such command r.cut?
...The category values in the new raster output map layer will be the same as those in the original, except that the resolution and extent of the new raster output map layer will match those of the current geographic region settings (see g.region)....
some illustrations to my problem:
Spearfish: soils cut on top of elevation
I tried this again:
Approach 1: r.mapcalc
Approach 2: r.resample
Tim,
Looks like it.
I asked for guidance on doing just what you need to do: cut out the
project area from a larger DEM.
The approach that worked for me was described by Helmut Kudrnovsky:
1) zoom to your area of interest of your larger region.
2) v.in.region e.g. "v.in.region output=testarea", so the extent of your
area of interest is defined by the vector "testarea"
3) "g.region vect=testarea", by this the region is set to your area of
interest for analysis. "This region defines the geographic area in which
all GRASS displays and raster analyses will be done."
I did nothing wrong.
But when performing the resample in the wxGUI I activated the button
"add to layer manager" below in the dialog window.
The resampled map ("cut") is then automatically added to the map BUT
without the overlay option of d.rast!
I changed the settings in the layer manager and ticked the -o option and
everything worked fine!
Helmut Kudrnovsky:
region.
"testarea"
done."
Works like a charm.
the v.in.region and g.region vect= steps are redundant, but
make sure when you zoom you update the computational region,
not just the display one in the GUI (d.zoom + d.mon does this
automatically)
the v.in.region and g.region vect= steps are redundant, but make sure when
you zoom you update the computational region, not just the display one in
the GUI (d.zoom + d.mon does this automatically)
Hamish,
Good to know. Thanks.
I'm a CLI person so I use the GUI only to start GRASS because I've hated
that crude, mid-1980s ncurses starting interface for years. Otherwise I much
prefer to work in a virtual console at the command line. Much more
comfortable for me. However, I will concede that I've found the LaTeX GUI
front-end, LyX, to be much quicker and more productive than writing LaTeX in
emacs. So I'm not totally averse to using the pointy-thingie when it's
demonstrably more productive.
LaTeX in
The same applies to the new GRASS GUI.
It's awesome and once you get acustomated pretty useful.
You may wanna use the CLI only for scripting...
