[GRASS-user] cvs make problems
I have a new computer with an AMD 64 Athlon X2 chip and a gig of ram. I want to install 6.3 cvs with 64 bit support. The steps I have followed (more or less are )
- cvs update (today)
- run CFLAGS="-O2 -mcpu=athlon -Wall" LDFLAGS="-s"
- configure with the options listed below
./configure \
           --enable-largefile \
           --with-postgres-includes=/usr/local/pgsql/include/ \
           --with-proj-includes=/usr/local/include/ \
           --with-proj-share=/usr/share/proj/ \
           --with-postgres-libs=/usr/local/pgsql/lib/ \
           --with-readline-libs=/usr/local/lib/ \
           --with-readline-includes=/usr/local/include/readline/ \
           --enable-64bit/ \
           --with-libs=/usr/lib64 \
           --with-readline=yes
- make
The make returns error 1. The first place I can find with a problem (although I haven't dumped the output to a text file is
Makefile:108: warning: overriding commands for target `clean'
../include/Make/Rules.make:34: warning: ignoring old commands for target `clean'
make[1]: Leaving directory `/usr/local/grass6/macosx'
if [ 0 -eq 1 ] ; then make -C locale; fi
cp -f AUTHORS COPYING README REQUIREMENTS.html /usr/local/grass6/dist.x86_64-unknown-linux-gnu/
cp -f /usr/local/grass6/bin.x86_64-unknown-linux-gnu/grass63 /usr/local/grass6/dist.x86_64-unknown-linux-gnu/grass63.tmp
build_html_index.sh
cp: cannot create regular file `../dist.x86_64-unknown-linux-gnu/docs/html/nviz/': Is a directory
chmod: cannot access `../dist.x86_64-unknown-linux-gnu/docs/html/nviz/grassdocs.css': No such file or directory
chmod: cannot access `../dist.x86_64-unknown-linux-gnu/docs/html/nviz/grass_logo.png': No such file or directory
Then I get a long list of modules with errors.
Any help appreciated!
Thanks, Jerry
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
Try using '-mcpu=athlon64'. I have a similar system which compiles
fine. Let me know if you still have problems.
BTW, you don't really need readline. IIRC, it's only used in r.mapcalc
for command history.
./configure \
           --enable-64bit/ \
           --with-readline=yes
- make
build_html_index.sh
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
Tried adding 64 and removing the readline stuff. Started from make
distclean. Still getting the same set of errors.
This error message is puzzling
Is there some string completion command that is missing a variable?
Jerry
-----Original Message-----
Sent: Monday, July 09, 2007 12:31 PM
To: Gerald Nelson
Cc: grassuser@grass.itc.it
Subject: Re: [GRASS-user] cvs make problems
or less are )
./configure \
           --enable-64bit/ \
           --with-readline=yes
- make
`clean'
build_html_index.sh
file or directory
file or directory
Jerry
I have recently made some changes to get (one day) parallelized compilation
working. Hope that the problem is unrelated (for me it works).
View this message in context: http://www.nabble.com/cvs-make-problems-tf4050368.html#a11524075
make clean?
make distclean?
(get rid of dist.x86_64-unknown-linux-gnu)
Hamish
