[GRASS-user] Cygwin fail to start up
I am trying to install GRASS 6.2.3 on windows XP.
I ran through the set up from cygwin.com and followed the instructions. I believe it has installed as the grass directory is located under the cygwin/usr/ directory.
My problem is I do not seem to be able to run cygwin. Using the shortcut or cmd line flashes the cmd line window up and then it disappears.
It is not in the task manager so I assume it is failing on start up.
This is a first time GRASS installation for me so I apologise if this is a user error. I have searched the archives.
Thanks in advance
Kirsty
