Hi Glynn,
This worked, thanks.
2010/5/11, Glynn Clements <glynn@gclements.plus.com>:
Hanlie Pretorius wrote:
I just pasted the code you sent at the end of the d.correlate script
That won't work. The "code" is a patch, indicating changes to be made
to the file. I've attached a complete modified version of the script.
#!/bin/sh
# MODULE: d.correlate for GRASS 6; based on dcorrelate.sh for GRASS 4,5
# AUTHOR(S): CERL - Michael Shapiro; updated to GRASS 6 by Markus
Neteler 5/2005
# PURPOSE: prints a graph of the correlation between data layers (in pairs)
# derived from <grass5>/src.local/d.correlate.sh
# COPYRIGHT: (C) 2005 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
# TODO GRASS 7: rename parameters to map1, map2 or better multiple
map=map1[,map2[...]]
#%Module
#% description: Prints a graph of the correlation between data layers
(in pairs).
#% keywords: display, diagram
#%End
#%option
#% key: layer1
#% type: string
#% gisprompt: old,cell,raster
#% description: raster input map
#% required : yes
#%end
#%option
#% key: layer2
#% type: string
#% required : yes
#%end
#%option
#% key: layer3
#% type: string
#% required : no
#%end
#%option
#% key: layer4
#% type: string
#% required : no
#%end
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." >&2
exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
CMDLINE="`basename $0`"
for arg in "$@" ; do
CMDLINE="$CMDLINE \"$arg\""
done
export CMDLINE
exec g.parser "$0" "$@"
fi
PROG=`basename $0`
#### check if we have awk
if [ ! -x "`which awk`" ] ; then
g.message -e "awk required, please install awk or gawk first"
exit 1
fi
# setting environment, so that awk works properly in all languages
unset LC_ALL
LC_NUMERIC=C
export LC_NUMERIC
if [ $# -gt 4 ] ; then
g.message -e "max 4 layers allowed"
exit 1
fi
TMP1="`g.tempfile pid=$$`"
ok=yes
for f in $GIS_OPT_LAYER1 $GIS_OPT_LAYER2 $GIS_OPT_LAYER3 $GIS_OPT_LAYER4
do
eval `g.findfile element=cell file=$f`
if [ -z "$name" ] ; then
g.message -e "$f not found"
ok=no
fi
done
if [ "$ok" = "no" ] ; then
exit 1
fi
d.erase
GRASS_PNG_READ=TRUE
export GRASS_PNG_READ
if [ $? != 0 ] ; then
exit 1
fi
# how many cmd line arguments?
ARGNUM=`echo "$CMDLINE" | tr -s ' ' '\n' | wc -l | awk '{print $1 - 1}'`
echo "CORRELATION" | d.text color=white size=4 line=1
colors="red black blue green gray violet"
if [ $ARGNUM -eq 2 ] ; then
line=4
else
line=2
fi
iloop=0
jloop=0
# get max in case of two maps for x, y axis
eval `r.univar -g $GIS_OPT_LAYER1`
max_layer1=$max
eval `r.univar -g $GIS_OPT_LAYER2`
max_layer2=$max
for i in $GIS_OPT_LAYER1 $GIS_OPT_LAYER2 $GIS_OPT_LAYER3 $GIS_OPT_LAYER4
do
iloop=`expr $iloop + 1`
for j in $GIS_OPT_LAYER1 $GIS_OPT_LAYER2 $GIS_OPT_LAYER3 $GIS_OPT_LAYER4 ; do
jloop=`expr $jloop + 1`
if [ "$i" != "$j" -a $iloop -le $jloop ] ; then
colorstmp1=`echo $colors | cut -d' ' -f1`
colorstmp2=`echo $colors | cut -d' ' -f2-`
colors=`echo $colorstmp2 $colorstmp1`
echo $j | d.text color=`echo $colors | cut -d' ' -f1` size=4 at=0,9$line
echo $i | d.text color=`echo $colors | cut -d' ' -f1` size=4
at=60,0$line
else
echo $i $j | d.text color=`echo $colors | cut -d' ' -f1`
size=4 line=$line
fi
line=`expr $line + 1`
r.stats -cnA input=$i,$j > "$TMP1"
m="`awk '$1>max1{max1=$1} $2>max2{max2=$2}
min1==0||$1<min1{min1=$1} min2==0||$2<min2{min2=$2} END {print
min1,max1,min2,max2}' $TMP1`"
m1=`echo $m | cut -d' ' -f1`
m2=`echo $m | cut -d' ' -f2`
m3=`echo $m | cut -d' ' -f3`
m4=`echo $m | cut -d' ' -f4`
awk '{print
"move",($1-min1+1)*100.0/(max1-min1+1),($2-min2+1)*100.0/(max2-min2+1);print
"draw",($1-min1+1)*100.0/(max1-min1+1),($2-min2+1)*100.0/(max2-min2+1)
}' min1=$m1 max1=$m2 min2=$m3 max2=$m4 "$TMP1" | d.graph color=`echo
d.graph << EOF
size 2 2
move 0 92
text $max_layer1
move 90 2
text $max_layer2
EOF
fi
fi
done
jloop=0
done
rm -f "$TMP1"
