[GRASS-user] d.labels
has anyone here noticed a potential problem with grass71 d.labels
module ?
Here is my concern.
I first generate a simple labels file on a two segment vector map:
v.label map=labeltest column=myattr size=12
Then I run it again with the -a option (rotate labels to align with
lines).
I see the label file now contains a "rotate" value for each label. No
change occurs for "east","north" label placement coordinates.
But I notice a x,y shifting on the map display, please see attached
screen captures.
I checked this does not happen with grass64.
Any idea ?
Vincent
(attachments)
