[GRASS-user] d.mon and world file
is there any quick way how to generate also a world file when storing
graphics into a file using `d.mon`. I just found `d.mon -g`, but it
needs some hacking.
It would be nice if `d.info` or directly `d.mon` could generate a
world file if requested.
Thanks, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Hi Martin,
graphics into a file using d.mon. I just found d.mon -g, but it
needs some hacking.
I’m not aware of that, but since I’m not sure what you are doing I need to ask if d.to.rast+r.out.gdal (or d.out.file) would help you here.
https://grass.osgeo.org/grass78/manuals/d.to.rast.html
https://grass.osgeo.org/grass78/manuals/d.out.file.html
The code you are looking for might be also in the following repo, but not using d.mon:
https://github.com/ncsu-geoforall-lab/grass-web-publishing
It would be nice if [d.info](http://d.info) or directly d.mon could generate a
Maybe a Python function to generate worldfile from the current computational region would be a better fit?
Vaclav
