[GRASS-user] d.mon start=cairo multi-layer PDF, PS, SVG output
Dear all,
I am trying to get output image files in various formats using the Cairo driver, following some very useful Python scripting examples:
https://baharmon.github.io/python-in-grass
When I try to map vector layers (e.g., point data) on top of raster layers (say a digital elevation model);
if I use PNG output file extension, both vector and raster layers show up with points having transparent background,
if I use PDF, PS, or SVG output file extension, only the vector layer (drawn last) is shown in the output image with white background.
Maybe the PS driver is a better option?
Yet, I was reading this old grass-dev post that may be relevant:
https://marc.info/?l=grass-dev&m=146346954429631&w=2
Kind regards,
Luigi
Sample test function I am using follows:
def make_map(outfile_name,
fig_width,
fig_height,
bg_color: Optional[str] = None,
file_types: Optional[list] = None):
“”" Test ouput map figure.
PLEASE CHECK as PDF and PS output does not get vectors displayed on
top of rasters. “”"
background_color = bg_color or [NO_BG_COLOR]
extensions = [PNG] if file_types is None else file_types
for extension in extensions:
outfile = pathlib.Path(OUT_DIR).joinpath(f"{outfile_name}.{extension}")
grass.run_command(“d.mon”, overwrite=True,
start=“cairo”,
width=fig_width,
height=fig_height,
bgcolor=background_color,
output=outfile)
grass.run_command(“d.rast”,
map=“raster_layer”)
grass.run_command(“d.vect”,
map=“point_vector_layer”,
type=“point”,
color=“150:0:0”,
size=20)
all other display commands
grass.run_command(“d.mon”, stop=“cairo”)
Bundled GRASS app for Mac from here:
http://grassmac.wikidot.com/downloads
System Info:
GRASS version: 8.0.dev
Code revision: 32930185c
Build date: 2021-07-01
Build platform: x86_64-apple-darwin20.5.0
GDAL: 3.1.4
PROJ: 7.1.1
GEOS: 3.8.1
SQLite: 3.35.4
Python: 3.8.8
wxPython: 4.1.1
Platform: macOS-10.16-x86_64-i386-64bit
g.version -b
GRASS 8.0.dev (2021)
./configure --with-macosx-sdk=/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk --enable-64bit --with-macosx-archs=x86_64 --with-opengl=aqua --with-openmp --prefix=/Applications/GRASS-8.0.app/Contents/Resources --with-freetype --with-freetype-includes=/Applications/GRASS-8.0.app/Contents/Resources/include/freetype2 --with-freetype-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-gdal=/Applications/GRASS-8.0.app/Contents/Resources/bin/gdal-config --with-gdal-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-proj=/Applications/GRASS-8.0.app/Contents/Resources/bin/proj --with-proj-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-proj-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-proj-share=/Applications/GRASS-8.0.app/Contents/Resources/share/proj --with-geos=/Applications/GRASS-8.0.app/Contents/Resources/bin/geos-config --with-jpeg-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-jpeg-libs=//Applications/GRASS-8.0.app/Contents/Resources/lib --with-png-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-png-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-tiff-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-tiff-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-postgres=yes --with-postgres-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-postgres-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --without-mysql --with-sqlite --with-sqlite-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-sqlite-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-fftw-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-fftw-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-cxx --with-cairo --with-cairo-includes=/Applications/GRASS-8.0.app/Contents/Resources/include/cairo --with-cairo-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-cairo-ldflags=-lcairo --with-zstd --with-zstd-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-zstd-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-bzlib --with-bzlib-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-bzlib-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-netcdf=/Applications/GRASS-8.0.app/Contents/Resources/bin/nc-config --with-blas --with-blas-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-blas-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-lapack --with-lapack-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-lapack-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-netcdf=/Applications/GRASS-8.0.app/Contents/Resources/bin/nc-config --with-nls --with-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-includes=/Applications/GRASS-8.0.app/Contents/Resources/include --with-pdal=/Applications/GRASS-8.0.app/Contents/Resources/bin/pdal-config --with-pdal-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-readline --with-readline-includes=/Applications/GRASS-8.0.app/Contents/Resources/include/readline --with-readline-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib --with-liblas=/Applications/GRASS-8.0.app/Contents/Resources/bin/liblas-config
Luigi Ponti
Dear list,
I am replying to myself just to say that I hit the same issues as shown at:
https://trac.osgeo.org/grass/ticket/3033
My apologies for not checking that first.
As I keep running into this problem, but there is not a lot of discussion on it, probably people have found other ways to deal with it (e.g., ps.map, which what I will try next).
Also, I noticed that the Python way was also explored:
https://discuss.wxpython.org/t/wx-image-postscript/25813
which I was actually about to ask…
Kind regards,
Luigi
On Thu, Oct 28, 2021 at 12:34 PM Luigi Ponti <luisponti@tiscali.it> wrote:
Dear all,
Kind regards,
Luigi
fig_width,
fig_height,
top of rasters. “”"
start=“cairo”,
width=fig_width,
height=fig_height,
output=outfile)
map=“raster_layer”)
type=“point”,
color=“150:0:0”,
size=20)
System Info:
GDAL: 3.1.4
PROJ: 7.1.1
GEOS: 3.8.1
SQLite: 3.35.4
Python: 3.8.8
wxPython: 4.1.1
g.version -b
Luigi Ponti
Hi Luigi,
ps.map (or g.gui.psmap/File > Cartographic Composer) is certainly an option. You can also have a look at m.printws in addons (mentioned in the ticket you linked), but it suffers from the same issues as the normal display since it is using d-commands.
https://grass.osgeo.org/grass78/manuals/addons/m.printws.html
I have tried to put individual layers rendered as SVGs together manually. That was too difficult to match, but perhaps if you clip vectors to a computational region you can match those.
Just to be clear, are you saying the ps driver (with GRASS_RENDER_PS_TRAILER etc) didn’t work for you?
Best,
Vaclav
On Tue, Nov 9, 2021 at 9:48 AM Luigi Ponti <luisponti@tiscali.it> wrote:
Dear list,
Kind regards,
Luigi
Dear all,
Kind regards,
Luigi
fig_width,
fig_height,
top of rasters. “”"
start=“cairo”,
width=fig_width,
height=fig_height,
output=outfile)
map=“raster_layer”)
type=“point”,
color=“150:0:0”,
size=20)
System Info:
GDAL: 3.1.4
PROJ: 7.1.1
GEOS: 3.8.1
SQLite: 3.35.4
Python: 3.8.8
wxPython: 4.1.1
g.version -b
Luigi Ponti
grass-user mailing list
grass-user@lists.osgeo.org
