[GRASS-user] d.out.file format=png file malformed
Friends,
     I'm using GRASS 70-svn on Arch linux to generate figures for a report. The general process is
1) GRASS - d.out.file format=png
2) xfig - import the PNG file, annotate, and export as PDF
3) TeX - import the file in a dvipdfm \special
    However, I'm now having problems with non-functional PNG files from d.out.file. Just below is a paste from my console. You can't see the error from inside xfig, but the line just below "xfig" is the stderr output from attempting to import demo_png.png.
GRASS 7.0.svn > d.out.file out=demo_png.png format=png size=800,600
                                Mapset <final> in Location <beartooth>
GRASS 7.0.svn > xfig
Warning: translation table syntax error: Missing '(' while parsing action sequence
'arning: ... found while parsing ':~Ctrl<Key>1: insert-string(1)
Warning: String to TranslationTable conversion encountered errors
libpng error: invalid file gamma in png_set_gamma
    The resulting PNG file will import into Imagemagick OK, and can then be exported back out as a PNG file which xfig will accept, so there is a work around, but maybe this is easily fixed? I've had a look at Anna's python script but haven't gone into the imported modules.
Thanks, Dave
David W. Roberts office 406-994-4548
Professor and Head FAX 406-994-3190
Department of Ecology email droberts@montana.edu
Montana State University
Bozeman, MT 59717-3460
On Fri, Jul 18, 2014 at 1:56 PM, Dave Roberts <dvrbts@ecology.msu.montana.edu> wrote:
Friends,
I’m using GRASS 70-svn on Arch linux to generate figures for a report. The general process is
  1. GRASS - d.out.file format=png
  2. xfig - import the PNG file, annotate, and export as PDF
  3. TeX - import the file in a dvipdfm \special
However, I’m now having problems with non-functional PNG files from d.out.file. Just below is a paste from my console. You can’t see the error from inside xfig, but the line just below “xfig” is the stderr output from attempting to import demo_png.png.
Mapset in Location
Warning: translation table syntax error: Missing ‘(’ while parsing action sequence
'arning: … found while parsing ':~Ctrl1: insert-string(1)
The resulting PNG file will import into Imagemagick OK, and can then be exported back out as a PNG file which xfig will accept, so there is a work around, but maybe this is easily fixed? I’ve had a look at Anna’s python script but haven’t gone into the imported modules.
I have never had any problems with exported images from GRASS. d.out.file uses the same mechanism as when you use the toolbar button in map display. I tried to get the png into xfig and it didn’t complain (xfig version 3.2.5b). Any other image processing tools have problems (e.g. gimp)?
Anna
Thanks, Dave
Department of Ecology email [droberts@montana.edu](mailto:droberts@montana.edu)
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Hi Anna,
    I hadn't tried gimp yet so I installed it to see. Works fine in both gimp and Imagemagick, so I guess it's an xfig thing. I'm running xfig 3.2.5c which is only slightly newer than yours, but maybe that broke it.
Thanks, Dave
On 07/18/2014 01:00 PM, Anna Petrášová wrote:
<dvrbts@ecology.msu.montana.edu <mailto:dvrbts@ecology.msu.montana.edu>>
wrote:
    Friends,
    ******************************__******************************__***********
    action sequence
map display. I tried to get the png into xfig and it didn't complain
(e.g. gimp)?
Anna
    Thanks, Dave
    ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~
    406-994-4548 <tel:406-994-4548>
    406-994-3190 <tel:406-994-3190>
    droberts@montana.edu <mailto:droberts@montana.edu>
    _________________________________________________
    grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
    http://lists.osgeo.org/__mailman/listinfo/grass-user
    <http://lists.osgeo.org/mailman/listinfo/grass-user&gt;
