Dear all,
I'm trying to plot arrows, representing length proportional to magnitude in a printable high resolution map (with d.rast.arrows). Here is what I tried:
#!/bin/sh
export GRASS_WIDTH=10000
export GRASS_HEIGHT=10000
export GRASS_PNG_COMPRESSION=0
#export GRASS_RENDER_IMMEDIATE=TRUE
export GRASS_TRUECOLOR=TRUE
g.region fig_arrows
d.mon start=PNG
d.rast map=background@PERMANENT
d.rast map=Magnitude_map@PERMANENT
d.rast.arrow map=Direction_map@PERMANENT type=compass arrow_color=black grid_color=none x_color=black unknown_color=red skip=12 scale=20 magnitude_map=Magnitude_map@PERMANENT
d.mon stop=PNG
eog $GRASS_PNGFILE&
Unfortunately the plotted arrows are quite slim now... is there another solution to achieve this goal?
Many thanks,
Niklas
GRATIS! Movie-FLAT mit über 300 Videos.
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome
Hi Niklas,
Same for me: the PNG driver draws thinner and thinner arrows when you
increase the resolution. If you lower the resolution it's okay though.
If you do need such a high resolution (for a poster?), you might try the
CAIRO driver (g.manual displaydrivers) which behaves quite differently
when producing PNGs. Arrows are drawn with a thicker pen indeed (even at
high pixel resolution) but you might be surprised by the raster
rendering... and files get very large.
Nicolas
Le mardi 02 novembre 2010 à 16:12 +0100, Niklas Neckel a écrit :
Dear all,
#!/bin/sh
g.region fig_arrows
d.mon start=PNG
d.mon stop=PNG
eog $GRASS_PNGFILE&
Many thanks,
Niklas
Hi Nicolas,
Thank you very much! The arrows are thicker now and are visible on the final plot.
Niklas
-------- Original-Nachricht --------
Datum: Tue, 02 Nov 2010 23:26:01 +0100
Von: "Nicolas Pérenne" <nicolas.perenne@free.fr>
An: Niklas Neckel <Nikneck@gmx.de>
CC: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] d.rast.arrows in high quality plot
Hi Niklas,
Nicolas
> Dear all,
tried:
> #!/bin/sh
> g.region fig_arrows
> d.mon start=PNG
> d.mon stop=PNG
> eog $GRASS_PNGFILE&
> Many thanks,
> Niklas
grass-user mailing list
