They run without error but nothing appears on the monitor. I can display
the map on Map Display 1, though. I'm using GRASS 6.3.0 with a 2.6.31
Gentoo kernel.
yes, this should display the map in the GRASS monitor (not the gis.m
output which is controlled by the gis.m display manager).
Gentoo kernel.
What am I doing wrong / missing? Thanks ...
It is not clear to me what you are missing.
To see maps in the monitor controlled by gis.m, use the layer manager.
To see maps in the x0 monitor, use the d.* commands.
