[GRASS-user] d.rast.edit does not save edited map although Save button is pressed
Hi, I must be doing something wrong with the following:
d.rast.edit input=track21_rast@PERMANENT output=track21_edited_rast
aspect=contours21_rast@PERMANENT width=640 height=480 size=12 rows=200
cols=200 --overwrite
The edited data is not saved in the output map which remains identical to
the input map, although I pressed the Save button in the grid display.
All the data is in my home directory (and anyway using "sudo d.rast.edit"
results in "d.rast.edit not found" error.)
Any clues what I might be doing wrong. ?
Many thanks
George
View this message in context: http://www.nabble.com/d.rast.edit-does-not-save-edited-map-although-Save-button-is-pressed-tp21011399p21011399.html
What is the nature of the editing? If the only changes are setting
specific cells to null, that's one thing which d.rast.edit can't
handle. You would need to set the cells to some unused value then
subsequently change them to nulls with r.null.
If you're changing cells to non-null values, then I don't know what
the problem is.
thanks Glynn, here is what I am doing. After I type the command two new
windows open up: one a grid with a faint outline of the input raster maps,
the other what I consider to be a navigation window, to help displaying on
the grid the area to be edited.
I want to extend the track21_raster map line, a walking track. So I click on
the cell nearest to the last colored cell in the grid and enter the two
category values I have, in the bottom grid display boxes: one called value
(I enter a 1, the track segment value), the other aspect (I enter the
elevation, 640) then press enter. (There is a third box called also Value,
which I leave blank as I don't know what to place there!).
A new whitish cell is created. I repeat the process for a few cells then
save, but nothing is saved. The output map is identical to the input. The
following is displayed in the terminal:
WARNING: Raster map <tmp.d.rast.edit> not found
WARNING: <tmp.d.rast.edit> nothing removed
Is it possible that the new cells are painted in white therefore invisible
when seen in the display? I have not found a way to change their color.
Any further help you can give will be most welcome.
By the way I am on GRASS 6.3 and Ubuntu 8.04.
d.rast.edit"
the problem is.
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://www.nabble.com/d.rast.edit-does-not-save-edited-map-although-Save-button-is-pressed-tp21011399p21020243.html
>> d.rast.edit"
> the problem is.
You can't enter values into the Value and Aspect fields on the top row
(it may let you type into them, but it won't have any effect).
You choose the new value either by right-clicking on a cell (to use
that cell's value), or by typing the cell value into the Value field
on the bottom row (to the left of the colour sample).
You can then set cells to the chosen value by left-clicking on the
cells.
George:
Glynn:
cells.
perhaps this is a factor here: http://trac.osgeo.org/grass/ticket/86
Hamish
