I am trying to use d.rast.edit and I can't get it to work properly. If I open it, either from the menu, or from the command line, it seems to open fine, but the size of my overview window is much larger then the size of my screen, so I can't see much of the window. If I resize the window then I don't get any scroll bars, so that doesn't help. So I can't figure out how to get to the lower 3/4 of my image. The edit window itself seems fine, but I can't get get it to select the correct part of the image, since I can't move to it in the overview window. What might or might not be relevant is that the only menu item that appears on either window is on the edit window I have a File menu with Save and Exit.
Am I missing something? Is there any way to force the size of the window to stay on my screen? Or to force it to just show a different section? I could edit the different parts at different times if I could get to that "lower" area at all.
I did try changing the region and the default region to see if that would allow me to choose a different part of the image, with no luck at all.
I am using the kyngchaos mac 6.3 binary builds with the newest Mac X11: 2.3.0 and the tcltk interface.
--Adam
That's a bug in d.rast.edit. The overview window consists of three
parts: the canvas (the portion containing the map), the vertical
scrollbar and the horizontal scrollbar. The canvas is supposed to grow
or shrink along with the top-level window, leaving the scrollbars with
a fixed width (vertical) or height (horizontal). However, the weights
were set on the wrong window, so everything tries to remain a fixed
size.
I have committed a fix in the current development version, but you can
fix the problem locally by changing lines 157-158 of
grass-6.3.0/etc/d.rast.edit.tcl from:
grid rowconfigure . 0 -weight 1
grid columnconfigure . 0 -weight 1
to:
grid rowconfigure .overview 0 -weight 1
grid columnconfigure .overview 0 -weight 1
With that change, the scrollbars should remain visible if the overview
window is shrunk.
size.
to:
window is shrunk.
That did it!
Thank you.
--Adam
