[GRASS-user] d.rast.edit with multiple maps
For the first time, I need to edit a raster. I need to improve some hydrological routing. I'd like to edit a DEM, but be able to view a slope map and the flow direction (output from r.watershed) to help with the editing. Does this capability exist in GRASS or an addon?
-k.
Ken Mankoff wrote
just tried it with following steps:
* raster map A as background, e.g. slope
* raster map B which should be edited, set transparency e.g. to 50%, to see
also background map A
* in map display -> Raster digitizer, then you can edit map B with
transparency e.g. to 50% and see map A in the background
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/d-rast-edit-with-multiple-maps-tp5331874p5331876.html
