[GRASS-user] d.rast fails on Windows 64 bit with GRASS 6.4.3 from Osgeo4W 32 bit
It’s a long time I don’t use GRASS on Windows. Now I’m preparing a course for Windows users and I was testing it.
I’ve been blocked from the beginning by d.rast not working. The point identify on the map returns correct results on the console, meaning that the raster is correctly loaded and managed by the various commands, but d.rast fails to generate the image.
Is it a known bug? Is my setup corrupted?
Giovanni
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/giohappy
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
During the initial loading in the layer tree I get:
File “C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\etc\wxpy
thon\lmgr\layertree.py”, line 1046, in OnActivateLayer
self.PropertiesDialog (layer)
thon\lmgr\layertree.py”, line 1036, in PropertiesDialog
completed = (self.GetOptData,layer,params))
thon\gui_core\forms.py”, line 1873, in ParseCommand
raise gcmd.GException(e.value)
core.gcmd
GException
Unable to fetch interface description for command ‘d.rast’.
Details:
Command ‘d.rast map=DTM_Prato@PERMANENT’ failed
2014-04-30 17:47 GMT+02:00 G. Allegri <giohappy@gmail.com>:
Giovanni
Giovanni Allegri
Giovanni Allegri
The problem has gone when I’ve set region settings according to my map. Probably d.rast couldn’t do its job because if memory problems.
Now both 2D and 3D views are working fine.
giovanni
2014-04-30 18:12 GMT+02:00 G. Allegri <giohappy@gmail.com>:
core.gcmd
GException
Details:
Giovanni Allegri
Giovanni
Giovanni Allegri
Giovanni Allegri
