[GRASS-user] d.rast.num
Dear all:
When I´m trying to execute d.rast.num in Grass71, an error appear that did not appear in Grass64:
GRASS 7.1.svn > d.rast.num MASK
Command ‘d.rast.num map=MASK grid_color=gray dp=1 text_color=black’ failed
Details: Current region size: 418 rows X 638 cols
Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible.
The problem is that my current region has only 323 cells:
GRASS 7.1.svn > g.region -p
nsres: 1000
ewres: 1000
rows: 19
cols: 17
cells: 323
Has anyone had this problem? Does anyone know how to solve it?
Thanks
Luis Barranco
Luis Miguel Barranco Sanz
Centro de Estudios Hidrográficos
Paseo Bajo Virgen del Puerto 3
28005 Madrid
Tel: 34 913357927
luis.m.barranco@cedex.es
On Wed, Sep 10, 2014 at 4:13 AM, Luis Miguel Barranco Sanz <
Luis.M.Barranco@cedex.es> wrote:
Dear all:
*GRASS 7.1.svn > d.rast.num MASK*
*Command 'd.rast.num map=MASK grid_color=gray dp=1 text_color=black'
failed*
*Details: Current region size: 418 rows X 638 cols*
*Your current region setting may be too large. Cells displayed on your
graphics window may be too small for cell category number to be visible.*
*GRASS 7.1.svn > g.region -p*
*nsres: 1000*
*ewres: 1000*
*rows: 19*
*cols: 17*
*cells: 323*
When you go to the Map Display statusbar and find item Display resolution,
do you have the checkbox 'Constrain display resolution to computational
settings' checked (it has to be checked for d.rast.num)? It should ask you
if you want to check it when you run the d.rast.num, I think.
Anna
Thanks
Luis Barranco
28005 Madrid
Tel: 34 913357927
grass-user mailing list
grass-user@lists.osgeo.org
