Salutations from Freiburg to all
@Hamish & company:
How do I "integrate" the d.frame.split script in grass63.1.svn, so I
don't need to call it from within its directory?
Thank you,
Nikos
@Hamish & company:
Thank you,
Nikos
@Hamish & company:
Copy then in the scripts directory of GRASS!
e.g.:
nik@vertical:/usr/local/grass-6.3.1svn/scripts$
cp /usr/local/src/grass-addons/display/d.frame.split/d.frame.*[rt] .
Sorry, that was an easy one.
Greetings from sunny Dunedin,
so I don't need to call it from within its directory?
put addons scripts in a dir someplace, then before you start GRASS set the GRASS_ADDON_PATH environment variable.
e.g. put this in ~/.bashrc:
export GRASS_ADDON_PATH=/home/you/grass/addons
Hamish
Nikos:
> don't need to call it from within its directory?Copy then in the scripts directory of GRASS!
e.g.:
that works, but you'll have to do it again each time you install a new version of GRASS. the GRASS_ADDON_PATH method is immune to that.
Hamish
