[GRASS-user] d.vect.chart
Could somebody explain me what is bad on this script?:
d.vect.chart map=water_chemistry_mgl type=point layer=1 columns=ca2_plus mg2_plus na_plus k_plus so4_2minus cl_minus hco3_minus ctype=pie ocolor=black sizecol=tds size=40 scale=0 colors=red green blue orange yellow cyan pink
I got the following output:
Sorry <ca2_plus> is not a valid option
Sorry <mg2_plus> is not a valid option
Sorry <na_plus> is not a valid option
Sorry <k_plus> is not a valid option
Sorry <so4_2minus> is not a valid option
Sorry <cl_minus> is not a valid option
Sorry <hco3_minus> is not a valid option
Sorry <green> is not a valid option
Sorry <blue,> is not a valid option
Sorry <orange> is not a valid option
Sorry <yellow,> is not a valid option
Sorry <cyan> is not a valid option
Sorry <pink> is not a valid option
I proposed that "columns" are columns with attributes. Did I misunderstand something?
Using Grasss6.3 last CVS, database PostgreSQL 8.1.4, running on Ubuntu 6.0.6
Many thanks in advance
Tomas
put commas between the column names:
columns=ca2_plus,mg2_plus,na_plus,k_plus,....
Hamish
