[GRASS-user] d.vect not using RGB values in attribute table
last weeks CVS:
using d.vect with the -a flag is not coloring areas based on colors stored in the attribute table.
| cat | muid | suborder_pct | soil_suborder | rgb | GRASSRGB |
| 2735 | CA007 | 15 | orthents | 254:1:1 | 254:1:1 |
tried using both an attribute named GRASSRGB, and specifying the column with the rgb_column=GRASSRGB flag
anyone else noticing this odd behavior?
Thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
I added wcolumn= and wscale= options last week. Hmm.. -a flag works well for
me. Try the following:
g.gisenv set=DEBUG=3
d.vect mapname -a 2>&1 | grep colorstring
Do you see any message?
Huidae Cho
On Sun, May 21, 2006 at 01:22:18PM -0700, Dylan Beaudette wrote:
last weeks CVS:
Thanks!
Dylan Beaudette
530.754.7341
grassuser mailing list
grassuser@grass.itc.it
Thanks for the quick reply Huidae,
After adjusting the DEBUG level, and executing the commands you suggested:
d.vect -a ca_statsgo 2>&1 | grep colorstring
D3/3: area 508: colorstring: 28:58:205
D3/3: area 2962: colorstring: 28:58:205
D3/3: element 11933: colorstring: 179:113:29
D3/3: element 12037: colorstring: 174:0:239
D3/3: element 12038: colorstring: 174:0:239
D3/3: element 12393: colorstring: 28:58:205
D3/3: element 12772: colorstring: 179:113:29
D3/3: element 12776: colorstring: 179:113:29
D3/3: element 13616: colorstring: 89:107:16
D3/3: element 13703: colorstring: 241:44:3
D3/3: element 13777: colorstring: 179:113:29
these appear to be the colors that I inserted into the attribute table, but my
polygons are still being filled with the default color of grey.
not sure what is going on...
I have just updated to todays CVS, and will check to see what happens when it
is done compiling.
Dylan
for me. Try the following:
Huidae Cho
> last weeks CVS:
> Thanks!
> Dylan Beaudette
> 530.754.7341
Dylan Beaudette
530.754.7341
Ok, a bit more information.
Rebuilt with today's CVS, and noticed that following:
D3/3: element 13860: colorstring: 254:1:1
D3/3: element 14253: colorstring: 202:158:185
D3/3: element 14290: colorstring: 110:182:71
D3/3: element 14369: colorstring: 254:1:1
D3/3: element 14847: colorstring: 28:58:205
D3/3: element 15466: colorstring: 254:1:1
D3/3: element 15508: colorstring: 254:1:1
D3/3: element 15640: colorstring: 181:166:34
... however there are hundreds of polygons in this map, and yet I only see
about 20 lines matching 'colorstring' .. note that a VERY small number of
polygons are being filled with a non-grey color- but I cannot detect any
pattern.
hereis a sample screen shot showing the results of the previous command:
http://169.237.35.250/~dylan/temp/d.vect_probs.png
vectors are labeled with their GRASSRGB attribute, note that only one of the
vectors has a fill color that differs from the default.
Dylan
Huidae Cho
> last weeks CVS:
> Thanks!
> Dylan Beaudette
> 530.754.7341
Dylan Beaudette
530.754.7341
Interesting... Were these polygons displayed correctly before I added wcolumn=
and wscale=? Or is this the first time you use -a for this map? try to insert
the following line just above "} /* end if table_colors_flag */" in area.c:
fprintf(stderr, "colorstring:: area=%d cat=%d rgb=%d r=%d g=%d b=%d\n", area, cat, rgb, red, grn, blu);
and run the same command. If you don't mind, could you send me (without CC to
the list) a copy of the map?
Huidae Cho
pattern.
Dylan
> Huidae Cho
> > last weeks CVS:
> > Thanks!
> > Dylan Beaudette
> > 530.754.7341
> > _______________________________________________
Dylan Beaudette
530.754.7341
Dylan,
Here is a screenshot of "d.vect -a mapname type=area". I have no idea what's
going on in your grass.
http://geni.ath.cx/tmp/screenshot.png
Does anyone have any idea?
Huidae Cho
On Mon, May 22, 2006 at 11:38:50AM -0700, Dylan Beaudette wrote:
> wcolumn= and wscale=? Or is this the first time you use -a for this map?
> try to insert the following line just above "} /* end if table_colors_flag
> */" in area.c:
> to the list) a copy of the map?
> Huidae Cho
Huidae,
thanks for the quick reply.
This is the first time that I have tried using the -a flag on this map.
here is a link to a shapefile of this map:
http://169.237.35.250/~dylan/temp/ca_suborder.tar.gz
I will try the source code modification a little later today.
Dylan
> > see about 20 lines matching 'colorstring' .. note that a VERY small
> > number of polygons are being filled with a non-grey color- but I cannot
> > detect any pattern.
> > the vectors has a fill color that differs from the default.
> > Dylan
> > > well for me. Try the following:
> > > Huidae Cho
> > > > last weeks CVS:
> > > > Thanks!
> > > > Dylan Beaudette
> > > > 530.754.7341
> > Dylan Beaudette
> > 530.754.7341
Dylan Beaudette
530.754.7341
On Monday 22 May 2006 11:47, Huidae Cho wrote:
Dylan,
what's going on in your grass.
Huidae Cho
Yikes... I just tried re-importing the shapefile that I sent you, and it
renders correctly.... I wonder if this has something to do with db
connectivity / naming issues...
I tried making a copy of the GRASS vector such that the copy had matching
vector and table names... but colors are still not displayed correctly.
I might have to give up on this for now, but it is very odd that features are
not being colored in the original vector.
I connected up the original table to the vector in question, and added a
GRASSRGB column to it. These colors displayed fine. However connecting a
different table to the same vector results in only a few areas being colored.
Interactively querying the vector with d.what.vect reveals that there are in
fact attributes associated with these areas, including the GRASSRGB values...
Dylan
> > map? try to insert the following line just above "} /* end if
> > (without CC to the list) a copy of the map?
> > Huidae Cho
> Huidae,
> Cheers,
> Dylan
> > > only see about 20 lines matching 'colorstring' .. note that a VERY
> > > small number of polygons are being filled with a non-grey color- but
> > > I cannot detect any pattern.
> > > command:
> > > of the vectors has a fill color that differs from the default.
> > > Dylan
> > > > Huidae Cho
> > > > > last weeks CVS:
> > > > > | GRASSRGB |
> > > > > Thanks!
> > > > > Dylan Beaudette
> > > > > 530.754.7341
> > > Dylan Beaudette
> > > 530.754.7341
> Dylan Beaudette
> 530.754.7341
Dylan Beaudette
530.754.7341
