Recent versions of GRASS (at least as of 7.3, maybe sooner) added a highlight feature to the wx query tool (or d.what.vect) that paints the selected feature yellow for identification. This works well when the map is all gray polygons, but changes the color scheme of colored thematic maps in a way I find confusing.
I would have expected that it would only influence the polygon I click on, but often other polygons change color as well, depending on their cat values in other tables.
Is there a way to turn this behavior off?
Dave Roberts
in other tables.
I don't think so. The problem is, it highlights all features with the
same category. Maybe this should be changed to highlight just the
specific feature? The underlying function already supports that, so it
should be easy to change. Should it be in settings perhaps?
Please create a ticket for this so that we don't forget about it.
Thank you
Anna
Dave Roberts
grass-user mailing list
grass-user@lists.osgeo.org
Anna,
Sorry, my two emails arrived in the wrong order due to some odd behavior of the email system. Comments interspersed.
in other tables.
You are quite right about this behavior. It would be nice to have a switch between highlighting cats and specific polygons.
As it turns out, however, the issue is related to ticket 3174 (see "map display query" email chain of Oct 4), where the query tool is reporting all layers, not just the layer specified in the d.vect command. In this case, the highlighting is based on cats in a different layer than the one I'm interested in, so perhaps when ticket 3174 is resolved the highlighting issue will go away as well.
OK. Last time I lacked a mantra and you did the ticket for me. I'll step up and get engaged.
Thanks for your always prompt and helpful answers, Dave
Thank you
Anna
Dave Roberts
