There was a discussion some time ago about the possibility of using Filemaker databases with GRASS. The newest version of Filemaker (9) makes a big deal of how it can work with sql databases. See http://www.filemaker.com/support/technologies/sql.html. You use (i.e. buy separately) an ODBC driver to allow Filemaker to access existing SQL databases as external data sources. I did this with some of my GRASS and other databases, using (so far) only the free trial version of the ODBC driver. The connectivity is now limited to MySQL, not Postgres, but this could easily change, I imagine, and may be possible to get around already; I haven't tried. I then created a dummy Filemaker file, which has no real data but is just a front end into that SQL database. it worked fine, although I haven't paid the $29 for the full version of the ODBC driver so I can't tell whether it's fast enough with large databases. With this system, though, I don't think you can create or drop databases, or otherwise administer them, adding or modifying fields, etc. So you still need to install postgres or mysql, configure them, and create the databases. You can populate the database in Filemaker, edit data, create reports, and such, all of which is pretty easy and intuitive. Then GRASS can access the mysql database directly -- not the filemaker database, but the data that Filemaker is accessing as an external data source.
For me, the advantages of using Filemaker as a front end didn't seem that great -- you still have to create & administer the databases, and there are some excellent tools for doing that. I like Aqua Data Studio, whose last version was free for personal use (the current one isn't, and I haven't used it). I've also tried CocoaMySQL, which is also free. Both have reasonably good editing tools. There are a large number of other front ends to postgres or mysql that offer a more intuitive user interface. This is probably more important than whether you use postgres or mysql or sqlite as the back-end database (I guess -- others will know better...). I haven't used OpenOffice.
This isn't exactly what you want -- you're looking for a driver that would allow GRASS to access native Filemaker databases directly, instead of having Filemaker access a sql database. I don't know if this is possible, but am interested in it if it were.
Nick Cahill
----- Original Message -----
Date: Wednesday, December 5, 2007 11:33 pm
Subject: [GRASS-user] Database for GRASS
To: grassuser@grass.itc.it
Hi folks,
I have some questions as to which databases people are using with
grass. I currently use Filemaker for as a database, but could never
get it to link to GRASS. I was wondering if this problem has been
resolved. Otherwise, I am considering which database software would
provide easy of use and still get the data I need ported to my GRASS
GISs. I contemplating Postgresql but it isn't all that intuitive.
How are MySQL and SQLite Browser?
Kurt
grass-user mailing list
grass-user@lists.osgeo.org
