[GRASS-user] Date import: setting projection units
As always, many ways to succeed in open source and GRASS. :slight_smile:
Helmut
Am 28.09.17, 15:46, Markus Metz <markus.metz.giswork@gmail.com> schrieb:
On Thu, Sep 28, 2017 at 3:38 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
Rich Shepard wrote
On Wed, 27 Sep 2017, Helmut Kudrnovsky wrote:
Another possibility is to let GRASS define the correct location
parameters
by the dataset itself.
Helmut,
I would prefer this but was not sure which coordinate-setting option
supports this for an OpenFileGDB directory.
it seems that OpenFileGDB directory isn’t recognized. you could file an
enhancement ticket for this.
a quick workaround with ogrinfo and grep. :slight_smile:
tested with an example fgdb downloaded somewhere from the net.
check the layers in the fgdb:
ogrinfo RH_SampleData.gdb
INFO: Open of RH_SampleData.gdb' using driver FileGDB’ successful.
1: Route (None)
2: Centerline_Sequence (None)
3: AADT (None)
4: Access_Control (None)
5: Base_Thickness (None)
6: Crashes (None)
7: F_System (None)
8: Speed_Limit (None)
9: Redline__ATTACH (None)
10: Centerline (3D Multi Line String)
11: Calibration_Point (3D Measured Point)
12: Redline (Multi Line String)
13: LRSN_MilePoint (3D Measured Multi Line String)
14: LRSE_Access_Control (3D Measured Multi Line String)
15: LRSE_Crashes (3D Measured Point)
16: LRSE_Speed_Limit (3D Measured Multi Line String)
17: LRSE_Functional_Class (3D Measured Multi Line String)
18: LRSI_MilePoint_Intersections (Point)
19: LRSN_RefMarker (3D Measured Multi Line String)
20: LRSE_Base_Thickness (3D Measured Multi Line String)
21: LRSE_AADT (3D Measured Multi Line String)
check the srs from one of the layers:
ogrinfo RH_SampleData.gdb LRSE_Crashes -al -so
Layer name: LRSE_Crashes
Geometry: 3D Measured Point
Feature Count: 14646
Extent: (215341.513300, 4712138.869500) - (360295.772500, 4806029.751300)
Layer SRS WKT:
PROJCS[“NAD83 / UTM zone 18N”,
GEOGCS[“NAD83”,
DATUM[“North_American_Datum_1983”,
SPHEROID[“GRS 1980”,6378137,298.257222101,
AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY[“EPSG”,“6269”]],
PRIMEM[“Greenwich”,0,
AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”,0.0174532925199433,
AUTHORITY[“EPSG”,“9122”]],
AUTHORITY[“EPSG”,“4269”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,-75],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AXIS[“Easting”,EAST],
AXIS[“Northing”,NORTH],
AUTHORITY[“EPSG”,“26918”]]
FID Column = OBJECTID
Geometry Column = SHAPE
ROUTEID: String (12.0)
MEASURE: Real (0.0)
DISTANCE: Real (0.0)
CASE_NUMBER: String (255.0)
CASE_YEAR: Real (0.0)
REFERENCE_MARKER: String (12.0)
ACCIDENT_DATE: DateTime (0.0)
ROAD_SYSTEM: String (2.0) DEFAULT ‘ab’
NUMBER_FATALITIES: Real (0.0)
NUMBER_INJURIES: Real (0.0)
REPORTABLE: String (1.0)
POLICE_DEPARTMENT: String (5.0)
INTERSECTION_NUMBER: String (2.0)
MUNICIPALITY: String (2.0)
NUMBER_VEHICLES: Real (0.0)
ACCIDENT_TYPE: String (2.0)
TRAFFIC_CONTROL: String (2.0)
LIGHT_CONDITION: String (1.0)
WEATHER: String (1.0)
ROAD_CHARACTER: String (1.0)
ROAD_SURFACE_CONDITION: String (1.0)
COLLISION_TYPE: String (2.0)
PEDESTRIAN_LOCATION: String (1.0)
PEDESTRIAN_ACTION: String (2.0)
EXTENT_OF_INJURIES: String (5.0)
REGION_COUNTY: String (2.0)
LOW_NODE: String (5.0)
HIGH_NODE: String (5.0)
ACCIDENT_TIME: DateTime (0.0)
REPORTING_AGENCY: String (100.0)
OFFICER_BUILDING_NUMBER: String (5.0)
DMV_ACCIDENT_CLASSIFICATION: String (1.0)
LOCATION_ERROR_CODE: String (3.0)
COMM_VEH_ACC_IND: String (1.0)
HIGHWAY_IND: String (1.0)
INTERSECTION_IND: String (1.0)
UTM_NORTHING: Real (0.0)
UTM_EASTING: Real (0.0)
REL_ACC_VEH: String (50.0)
CRASH_SEVERITY: Real (0.0)
FROMDATE: DateTime (0.0)
TODATE: DateTime (0.0)
TEST_DOMAIN: Integer(Int16) (0.0)
EVENT_ID: String (50.0)
LocError: String (100.0)
grep the srs info into a text file
ogrinfo RH_SampleData.gdb LRSE_Crashes -al -so | grep -A22 -B0 PROJCS >
my.prj
and in the GRASS start up wizard choose:
Read projection and datum terms from a Well Known Text (WKT).prj file.
all done.
Shorter version:
v.in.ogr input=RH_SampleData.gdb layer=LRSE_Crashes output=LRSE_Crashes location=name_of_new_location
Markus M
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
grass-user@lists.osgeo.org
