[GRASS-user] Datum <Sphere_ARC_INFO> not recognised
Hello,
I was creating a new location based on the shapefiles here:
http://www.epa.gov/wed/pages/ecoregions/na_eco.htm#Downloads
I was a little thrown by this error:
canada_lcc:PERMANENT> g.proj -c
georef=~/grassdata/downloads/cec-ecoregions/level1/NA_CEC_Eco_Level1.shp
location=cec_ecoregions
WARNING: Datum <Sphere_ARC_INFO> not recognised by GRASS and no parameters found
This is just a warning, and the location was created. I still get the
warning when importing the actual vector map:
cec-ecoregions:PERMANENT> v.in.ogr
dsn=~/grassdata/downloads/cec-ecoregions/level3/NA_CEC_Eco_Level3.shp
output=cec_level3
I've now got my data imported, and I've confirmed it was done properly
by re-projecting it to other locations. So there isn't a problem.
However, I'm curious what the warning means? Is this something I can
safely ignore?
Tyler
On Thu, Oct 4, 2012 at 6:12 PM, Tyler Smith <tyler.smith@mail.mcgill.ca> wrote:
Hello,
output=cec_level3
safely ignore?
I am not sure. It seems to be some ESRI magic:
http://forums.esri.com/Thread.asp?c=93&f=984&t=235780
as well as EPA magic::
http://spatialreference.org/ref/sr-org/80/
http://spatialreference.org/ref/sr-org/80/prettywkt/
In the worst case you could update the loc/mapset/PROJ_INFO file
manually to get the "g.proj -w" output right.
