With the epsg code " 2961" in Grass i have the sames problem and message without changing the shape code from Mapinfo. Mapinfo doesn't reconize the 2961 code . The availaible Mapinfo codes are in the attached file; in some lines you find the epsg code like "p........"
To: "pierre rella" <p_rella@hotmail.com>
CC: grassuser@grass.itc.it
Subject: Re: [GRASS-user] DATUM WGS84
Date: Thu, 3 Aug 2006 15:33:43 -0400how about EPSG 2961?
On 8/3/06, pierre rella <p_rella@hotmail.com> wrote:
> I am working with grass6.1 with windows 2000 OS. I use datum
> WGS84 with UTM 20 North projection. But Grass don't reconize this datum
> that code list EPSG from grass confirm. I don't find others projections
for
> the Antilles Zone (Guadeloupe) compatible with commercials solutions(
> Mapinfo or Arvcview)
> How can't i do?
> Best regards_______________________________________________
grassuser mailing list
(attachments)
MAPINFOW.txt (126 KB)
